Recently changed the oil in the pump section of my electric pressure washer. Although technically a non-serviceable item, I was in there repairing a problem. Although difficult to describe, the pump section uses 3 plungers operated by a shaft spinning a canted washer, the washer as it spins slides across the top of the plungers pushing then down and releasing them. Needless to say this is a high wear design, and the oil in there was nasty. All I had laying around was some PP 5-30 so I used that, unfortunately it doesn't work well and I end up with some nice rainbows in the water sitting around the pump.
The original oil was thinner than gear oil, and looked to be a bit thicker than the 5-30 I put in. Unfortunately that is all I can tell you about the oil.
Any recommendation other than some cheap ~40w for the pump?
