Bluestream, I am not sure what you have against Waxoyl, but your posts are WAY off base. I live in Vermont and pound my Land Rover down dirt roads (sprayed with sodium chloride in the summer to keep dust down) and we get 6 months of salt... basically the harshest corrosion environment with the most rust prone vehicle ever, so trust me when I say- Waxoyl is THE BEST CORROSION PREVENTION ON THE WORLD. Hands down, bar none.
The comments regarding trapping water in are totally wrong. Assuming he isn't intentionally slandering Waxoyl, the only explanation is the Waxoyl was applied onto of another product which had trapped the moisture. I say this with confidence as Waxoyl displaces moisture to make a permanent bond with the metal. On several occasions, I have pressure washed vehicles and applied Waxoyl to the wet vehicle and achieved a perfect bond. I prefer to let a vehicle dry before applying as it makes less mess during the application, but you can apply it right over water. Here is a clear example- You can spill Waxoyl in a sink full of water, it will float. If you push it to the edge, it bonds with the the sink as if you had sprayed it to a dry surface.
Regarding your comment "If it was so great why is in not used in the largest market for rusty cars".. Waxoyl had issues with the USA distributor (they started making their own cheaper product selling under the Waxoyl name! Big no-no, ended in a lawsuit) and so pulled out of the market for a long time. Rovers North is the new USA importer and distributor. You can buy the product from them.
... As you can tell this is my first post here. I love Waxoyl so much (I put it on all my friends and families vehicles!) that I had to jump on here and defend the product!
Waxoyl is the best!
Waxoyl is the best!
