OCP stands for Olefin Co-Polymer. They are made by polymerising ethylyene and propylene. If you over-do the ethylene, then the OCP has a tendency to become crystalline at very low temperatures and quiescent conditions. As a result, they tend to need more Pour Point Depressants to meet the MRV spec. However the real problem with high ethylene OCP is that sometimes, even when it passes all of the tests (including MRV) it can still gellify the oil in the field. Many years ago, I recall seeing a letter from Oronite relating to an incident in Hokkaido, Japan where this kind of thing happened.
In my experience, blending different oils made from high and normal ethylene OCP VIIs doesn't cause compatibility issues with HTHS, KV100 and CCS. MRV I'd say was also compatible but I wouldn't stake my life on it!
