Originally Posted By: ls1mike
Originally Posted By: DBMaster
Intake and exhaust modifications don't help much, unless the increased noise makes you THINK the car is more powerful. To use the "increased" airflow coming in and the increased exhaust flow your engine would also need to increase its flow of gases. So, without cam, valve timing, and fuel injection modifications there's not going to be much benefit.
I am not saying you get nothing. You just don't get much more than placebo effect.
Might want to caveat that it depends on the platform. An LS motor like my WS6 has does respond to those things well. Exhaust and SLP netted 26 RWHP on the Dyno without a tune 36 with a tune. It is not the same for all engines.
I agree. My LS1 picked up a noticeable amount of power above 5000 rpm when I did the cat-back exhaust and the SLP airbox and big MAF on the intake.
