Originally Posted By: kschachn
The issues with some 1MZ-FE engines is not a myth, I have seen it first-hand. The PVC system on the earlier engines is poorly designed and the head temperature (especially in the rear bank) is very high. Later 1MZ-FE engines had modifications to address the issues plus a lower recommended OCI from Toyota.
The one affected engine I saw was short-tripped in cold weather with long OCIs on bulk dino. Even from the affected years, not all 1MZ-FE engines were equally susceptible.
Just because you have a later, unaffected 1MZ-FE that doesn't mean the issue was a myth. Way over-hyped yes, but not a myth.
And there you go, myth destroyed. VW, GM engines will sludge with the same abuse you describe. The problem is people like to abuse Toyotas because they think they can, and the company will protect the brand by paying to settle torts.
The fact is, no one has demonstrated sludging in a non-abused engine, and in conditions that wouldn't affect other makers engines, too. There are plenty of engine bay designs that run equally hot and with similar or lesser PCV arrangements.
I also have to point what Camrydriver111 says, it can't both be a self-destroying engine AND widely considered one of the best V6s ever built. Can't have it both ways, honestly. Much more reliable than the GR and some newer designs.
