What options do I have for coolant for this vehicle? I am having trouble finding out which coolant to use. I figured I can use Peaks Final Charge? What other coolants are compatible?
If you want a coolant that will give you all of the protection of green, and extended life without the silicate, SCA, or 2-HEA, Rotella ELC is your coolant.
Originally Posted By: BigBuck
Ok so I'm going to go get some green. Its so hard to find info on this truck. It's the old body style heavy duty version and it's the last year of it
Hmmm....
I have a '97 F250 with the 5.4 and 7-bolt wheels (it's actually a heavy half) and I haven't had too many problems finding info on it, but I guess the repairs on mine have been few. I believe the most sought after item on your truck would be the engine block that is drilled to accept factory roller lifters. I'm actually looking for a similar 351W block for an upcoming engine build...but I digress.
