I changed the front brake pads on my Jeep about a month ago. Today it was really hot and I had several long downhills where I had to brake for traffic and lights.
I kept thinking I smelled burning brakes. When I stopped for a red light, sure enough I saw some smoke coming from my passenger side tire/wheel area. I had to go about another 3 miles to get to a place with some water and area to pull wheel and look about.
I poured a couple gallons of water on the hub and brake assembly to cool them off after I got wheel off. The pads were still compressed to the rotor somewhat and the wheel would not turn freely.
So I took a tool and broke the pads free of the rotor and got the assembly to move freely. I then drove it home. Luckily most of it was freeway and did not require any braking. I used emergency brake when I did have to brake and slowed down long before I had to.
Any way, I got home without further problems or brake issues. My question is should I or do I need to do anything with those pads? And if so, what do you recommend?
Thanks to all
Thanks to all
