Originally Posted By: sayjac
Originally Posted By: dnewton3
..... But when it comes to pragmatic applications for my home/vehicles/equipment, I eschew emotion and look to facts.....
And yet, you ran a non spec FL400S oil filter application as documented in the link below because, "
it's what I wanted to use".
http://www.bobistheoilguy.com/forums/ubb..._qu#Post3536592
So the quoted conclusion below would also apply to your use of FL400S.
Quote:
The reward is imagined.
The risk (admittedly remote) is real.
Yes, I "wanted" to run it. At least, sort of ... It was, in fact, a mistake initially on my part; I grabbed the wrong filter at that moment of installtion. The Villager has an in-block bp valve; it does not need one in the filter. The FL400S has a bp in the filter. There is nothing unsafe about running two bp valves; running no bp valve is a bad idea. So I "wanted" to run it and see what would happen; my theory is that nothing bad would happen. I thought " ...
what the heck; give it a try ..." But at least I had a theory that I was attempting to quantify with data, unlike most here. My entire intent was to run much longer OCIs; I "wanted" to prove beyond doubt that "normal" filters and oils are grossly underutilized. My two back-to-back experiments with lubes/filters extended to 2x and 3x the OEM OCI was an experiment I "wanted" to run. In fact, you could even say it was a factor of 5x, because the OEM severe criteria is 3k miles, and I ran out to 15k miles. At the time my wife's driving qualified as "severe" by their definition, and nothing bad happened at all, despite running the oil/filter out 5x longer than "recommended".
You see, I "wanted" to prove my hypothesis with facts. So I "eschewed" the normal mantra and tested my theory. My evidence (both UOA data and filter dissections) showed my theory valid.
For those who "want" to upsize a filter, I challenge them, you and anyone else to show that the upsized filter provides a tangible statistical difference in performance of wear-rate control. To date, exactly NO ONE has EVER been able to prove it here.
The desire to upsize is fine by me; do what you want. But we should not, as a BITOG group, pretend that theory equals reality unless we can PROVE it. I proved that longer OCIs are safe and achievable, and that wear rates actually drop as the OCI matures. But I have yet to see anyone prove that a slightly upsized filter has any ability to affect wear rates in normal applications. Never.
If you're going to nit-pick my words, at least take them in context, please. Don't try to play word games here; it's not becoming of anyone. You know what my intent was.
When I stated that longer OCIs return lower wear rates, I did so after running very large macro data analysis (see my article). I also tested the theory locally in my own garage with multiple OCI extensions. And, there is an SAE study that also back this up. That's THREE different, unlinked methods of credible testing that all point to the same conclusion. I "wanted" to test the theory, and I proved it via three separate methods.
When others state that a "bigger filter is better", I have yet to see any of them prove it with any means testing. There is also no credible SAE study that speaks directly to this topic. So far, this is all theory and no proof.
Do what you want, but what you want and what you can prove are two totally different things.
For my experiments, the risk was real, but so was the reward. I proved that OCIs can be safely extended.
For the OP, and everyone else here, there has been no credible evidence presented that a larger filter results in some "better" tangible result (presumably less wear?) in normal applications, such as what the OP intends.
