Originally Posted By: jdavis
I'm going to run a 15k OCI on my 2004 Accord, M1 0w-20 EP, Fram Ultra, 121k miles on the car, I've had it since 120k miles and don't know the history, roughly 80% highway, will do a UOA after, thoughts? I'm going to clean the sucker out.
Most Honda engines, this one included, seem to be pretty easy on oil, so I can go with the notion of running 15K with a solid oil on a commute of 80 miles each day.
What gives me pause is where you write that you've owned the thing all of a thousand miles and its history is unknown.
I'd feel better doing a few 5K runs of something decent and then going for 15K.
A UOA might be ideal, but probably not really needed.
My thinking is that a few shorter runs of any decent oil should clean up any gross deposits which you might not want to have circulating for 15K and which might even overwhelm the detergent/dispersant capacity of M1 EP on a really long run.
We all like to think of the oil filter as catching all debris, but a lot of it remains suspended in the oil since the particles are too small to be filtered out. All is well until the dispersant capability of the oil is overwhelmed and these small particles start aglomerating into larger and more damaging ones.
JMHO
