Yes, but the oil that is already in the bearing, or between the camshaft and the lobe, or between the cylinder wall and the piston is still thicker, therefore the pressure is higher. The oil pressure in the oil galleys is controlled by the bypass spring, but thicker oil can result in higher visco-dynamic pressures within the operating components.If you look at CFD modeling of oil flow in a bearing vs the idealized classical models discussed in the Haas articles, you will actually maintain better clearance with thicker oils in many cases despite the decreased flow rate.
