My Jeep 4.0 is probably going to toss a piston skirt before too long. Not a lubrication failure.
A friend of mine has a 2005 Accord. He REFUSES to change the timing belt and runs 10K on whatever the cheapest oil is. The engine isn't going to die from 10K oil change intervals on cheap conventional oil, it's going to die from the timing belt snapping.
I can only think of a few, very rare, cases. Like Toyotas and Saturns coking their rings causing oil consumption ... which would be avoided by checking the oil.
or someone running 20w-50 in -50 temperatures - not a fault of the lubrication as it was not used as intended.
