Yesterday I bought a used 2013 Crestliner Fishhawk 1600. It has the Mercury 60 hp ELPT four stroke on it. Prior to buying it I did some research as to recommended oil and read that many use a 25W40.
When I picked it up I spoke with the tech who went over the boat with me. I asked him what oil they used. He said they put 10W30 in everything.
As he was explaining why they use 10W30 (because it gets cold here in NY) I noticed a sticker on the top of the engine. It shows Mercury recommends 10W30 from zero to 40 degrees Fahrenheit. It then recommends a 25W40 from zero though and above 40. I basically will use this boat from late April through October.
I think I am going to dump this oil soon. The question now is do I go with a 25W40 Quicksilver oil or an HDEO like Rotella 15W40? Does Quicksilver have additives a marine engine needs that Rotella doesn't?
The excuses the tech had for using 10W30 were weak at best. Especially since there was a sticker on the engine explaining that 25W40 can be used during cold weather. Thanks for any advice.
