Originally Posted By: DBMaster
One of the features of the Mazda Skyactiv engines is an electronically controlled variable pressure oil pump. The primary purpose is fuel economy - minimizing parasitic drag, but might it not also ensure adequate oil pressure regardless of viscosity?
Great question. Of course only if it closes the loop on oil pressure itself!! Possible, although I'd guess it just follows a set schedule of oil volume vs. RPM.
My investigations centered around just whether or not an engine computer can detect low-ish oil pressures due to fuel dilution and/or VII shearing-breakdown over time. Or maybe oil oxidation or soot loading producing high viscosity. So many DI engines have this fuel dilution problem (not just Mazdas) that its something we have to consider now. DI is here to stay.
If the Mazda variable oil pump is like the GM one: http://www.machinerylubrication.com/Read/26274/Oil-pump-Chevrolet-Cruze
then it depends only on an RPM schedule, not oil pressure feedback (relief valve only).
