Originally Posted By: Vikas
Do other Audi owners have problem with the cam before realizing it needs replacing? I mean nobody takes the valve cover off to make sure the camshaft is still intact!
Audi has yet to build a vehicle where the valve cover didn't need to come off regularly, like every 40-50k miles, to seal leaks. The 30V V6 is the pinnacle of oil leakage.
Typically, there will be a misfire code because at some point the cam lobe will be so worn down the valve will hardly open anymore.
