Wow, there must be a million forum debates on this topic! Honda says it is preferred and aftermarket DOT 3 can be used only temporarily. I would say 80% say aftermarket is ok and 20% say use Honda only because Honda says so. Neither side can offer hard factual evidence to support their beliefs.
I have used only Acura/Honda in our 2010 MDX because it was under warranty. Yesterday I flushed the front wheels but ran out of Acura fluid before I could do the rears. Now I have to decide whether I drive way out of my way to get Honda fluid or go to my convenient parts store and get a good quality aftermarket fluid to finish the job. I am inclined to get Honda fluid and then change to aftermarket on my next flush.
I believe the Honda recommendation is connected to the Toyota/Honda master cylinder recall which Toyota blamed on using aftermarket fluid. This, of course, was a lie because the failures were ultimately traced to a batch of faulty seals supplied to both Honda and Toyota.
So, for the 14th million time, is it ok to use aftermarket DOT 3/4 in my 2010 MDX? Ok to mix Acura DOT 3 and aftermarket DOT 3/4 in my MDX? Thanks.
