Hello folks. Which of these two oils would you choose? I see that Smitty's Super S is a good product but Pennzoil seems good also. Which would you choose all things considered. I apologize now if this subject has been discussed
Having not heard of Smitty's before (not that it means anything) and given only these two choices, I would opt for the Pennzoil Gold--which by all accounts seems to be a good oil. BlueOvalFitter ran it in his F150 and I believe garnered good results from the run. I assume this is the one that you are considering from Smittys?
