AI-11P Lubricant
Ontario
Hyundai calls for AI-11P rated lubricant for the brake caliper pins but I can't locate a lubricant that has this spec. Any recommendations for where this can be purchased?
I normally use Napa Syl-Glyde for the pins on my other cars.
Thanks.
if it's just metal to metal (caliper guide pin), with some kind of rubber (elastomeric) moisture boot of some sort, Syl-glide will work just fine.
Don't need to be all that specific RE: factory recommended brake caliper/parts lubricant. Chances are: they aren't avail in NA.
Q.
