My Corolla sounds quite a bit different at cold (20F) startup on the Penzoil PP 0W-20 that the Mobil 1 AFE. Any technical reason for that?
With Mobil 1 at startup it would make a 'slushy' should about 3 seconds after startup. As if the oil was water being slushily sprayed over the cams. Almost an woosh sound.
With Penzoil PP at cold startup it doesn't sound the same at all. It doesn't have the 3 seconds and then a slushy flowing sound at all, not mush sound other than the engine.. I anything, the slushy flowing sound is longer delayed and pulses every few seconds in and out after about 7 seconds.
Some kind of cold flow difference?
