Originally Posted By: SteveSRT8
OP, completely platform dependent.
For the majority of slushboxes a pan drop is about 1/3 the capacity.
Fluid exchange through the lines is the only way to even hope of swapping the majority of the fluid...
That is the point of the thread. According to him, unless it is a Honda, the fluid exchange through the lines only replaces the same amount as a pan drop/drain/refill which is nowhere near all the fluid.
Thank you for your comment. At what point did I lose you?
