Originally Posted By: badtlc
No, he said ATF will flow just fine through the cooler lines but due to the transmission design, you will only have access to about 40% of the fluid. So, if you run 15 quarts through the cooler lines, when it is all said and done, he said you have still only replaced 40-50% of the capacity due to the design trapping the rest.
I can't quite wrap my head around this (either the original claim by your transmission guy or this clarification). If you're always pumping fluid through the system, then new fluid will replace old fluid (even in gravity drained areas, similar to oil "trapped" in a cylinder head valley) and the old fluid will eventually move to the sump.
If his claim is that you can't quickly get 100% of the fluid out, then I could agree with that. For example, if you have a 10 quart sump and you exchange 10 quarts through it, you'll still have a lot of old fluid, or at least old fluid that's mixed with new. Maybe his claim is that you'd have to pump 30 quarts of fluid through it before you'll get almost all of the old out (and this is more than the customer is willing to invest at the time). Perhaps that is true.
I'm not certain, by the way, how the Honda transmission would differ here. I realize that it's a different design, internally, from most transmissions, but you're still going to have areas where you have old fluid that has to be physically mixed then displaced by new in a gravity drained area.
Edit: I re-read the original claim, and it was that you could run all the fluid through it you wanted, and you'd still only get part of the old stuff out. That means that there is some fluid that will NEVER EVER be cycled through the system (or even filtered) and I'm not sure I subscribe to that.
