Originally Posted By: Delta
Originally Posted By: Turk
Originally Posted By: FL_Rob
Hence,..this.
www.bobistheoilguy.com/forums/ubbthreads.php/topics/3569537
Yes, this.
The Mobil 1 TDT stopped my 2003 5.3L from "clacking". Not "slapping". Started it again outside in 15F weather & purpously left the door wide open to listen carefully. NO NOISE. GONE. The M1 TDT has been in for 2,000 miles, btw.
I previously owned a 2000 5.3L that had piston slap. I know what piston slap is, and on my current 5.3L, it was not "slapping".
OP: Put in M1 TDT, run it some and report back with your results.
Please PM me so I am sure to see it.
Might be short lived. I ran/am running a HDEO 10w30 in the 3400 powered Equinox in my sig. It pretty much made the cold "clacking" go away, until about 3700-4000 miles later on the oil it's back. I'm tired of worrying about it, lol. Seems it is a GM thing, was gonna run a 40wt, but I'm just going to stick with the normal regimen. It's got about 6500 on the oci as of now.
If you don't mind thicker I suggest a euro spec oil such as m1 0w-40 or a castrol equivalent.
They can be bought inexpensively and the quality of European certified oils is very high.
You can use a 0w-40 all year long. They qualify for 10000 mile drains. Great for turbo engines so you know they can handle the heat and the equinox had some issues in the past so Chevy shortened the interval and adjusted the oil life monitors,which becomes moot if you use a euro spec oil,in my opinion.
So if you don't mind going a grade thicker I feel a euro spec oil satisfies
Jmo
Hence,..this.
Yes, this.
Jmo
