Originally Posted By: Shannow
My first car was a heavily neglected Inline six, with 7 years on 20W50 dino (and Lord knows what before that), so badly sludged, that the rockers had their own tracks int eh valve cover...I scraped out a couple quarts of black gunk in rocker and sideplates.
Filled with Kero (no oil) and just idled it...drained out like black used oil, thick...did it again, then a couple of very shorts OCIS on rubbish oil.
Used a litre of diesel every OCI as an idle flush for some time after that.
I was young, and lucky...it worked, and did no damage...I'd do it again, but probably with diesel rather than Kero.
bobbydavro has an interesting point
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3546847/Re:_Castrol_0W-30_Belgium_vs_C#Post3546847
Originally Posted By: bobbydavro
Ive know ultra high performance race oils use un-additised diesel as a base oil with rediculous levels of friction modifiers
I don't doubt that if you can get some FM in there, you could do a diesel flush quite safely at idle, multiple short periods, no load....now biodiesel, esterified edible oils could be amazing in such an application.
Esterfied edible oils?
Like canola oil for example.
We had a member here using canola at least in some part in his engine. He was messaging me with updates but I haven't seen nor heard anything recently.
So would canola oil work,albeit probably not as fast as a solvent but not quite as risky either.
