The older 7.3 IDI in my sig does fairly well using a blend of 15W40 & some NextGen MaxLife 10W40, carrying a CF rating, to slow down the oil cooler & rear main leakage somewhat-but I'm not going to push it past 3000 miles or so. My 300D had been abused by long OCIs using Castrol GTX when I bought it-to the point that the compression was suffering due to soot clogging the rings, but Mobil 1 TDT helped that quite a bit. In my (limited) light-duty diesel experience, it's the ability of HDEO to agglomerate (collect) soot so that the oil filter can catch it that is the big factor, along with higher ZDDP levels (but newer low SAPS HDEO oils have a lot less of those, obviously not as critical).
