Hopefully I am not the only one who sees similarity between the following two paragraphs!
"DON: This is a nice first sample from your Cayman -- especially considering this oil saw over 10,000 miles.
Universal averages in the far right column show normal levels of wear for this type of engine [Don: meaning, Gasoline] after about 4,400 miles of oil use. Your wear metals look great compared to averages on a much longer oil, showing that this engine is happy and healthy at 40,540 total miles and wearing much better than others of its kind. The only "bad" mark here was for a low flashpoint, indicating a trace of fuel present. That much fuel is harmless. The TBN was 3.7, good. Fantastic engine!"
This Monday, August 25 is a day worthy of champagne, caviar and confetti. With the new moon in Virgo energizing the skies, you’re having your astrological New Year. Sit down with your trusty journal and map out some resolutions. What grand goals would you like to pull off by the corresponding full moon in Virgo on March 5, 2015? Be a bit more “selfish” about it, because this is one day of the year that really is all about you. Besides, when you’re brimming with happiness, everyone around you benefits. So you may as well take charge of your own destiny in the name of lifting others up by sheer example. If there’s a chasm between your desires and your current skill set, begin the search for online courses, coaching and specialized training. Now is the time to invest in your own growth so you can spread your wings and soar.
