Hate those adds that start with, "Lean 1 weird ...
by OneEyeJack
04/30/16 05:11 AM
How Much Olive Oil Do You Use?
by GrtArtiste
04/30/16 03:20 AM
Hyundai filter 26300-35503 10PK for 35.40 FREE S&H
by GumbyJarvis
04/30/16 01:10 AM
Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
04/29/16 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
04/29/16 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
04/29/16 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
04/29/16 09:16 PM
UPS package tracking is so confusing!
by Klutch9
04/29/16 07:52 PM
Dupont non-stick lube
by buck91
04/29/16 07:47 PM
House electrical wiring question
by road_rascal
04/29/16 07:46 PM
Air pressure question
by aquariuscsm
04/29/16 07:43 PM
Fllow the DOT's
by WyrTwister
04/29/16 07:23 PM
hdwizard21, raihan, aceracres, kg4geq, red_bulldog
57748 Registered Users
36 registered (06AllAmerican, 2002 Maxima SE, Al, Abakev, AEHaas, 1foxracing, 3 invisible), 709 Guests and 295 Spiders online.
57748 Members
66 Forums
248234 Topics
#3442104 - 07/31/14 06:51 PM Amsoil AFL or EFM for 2002 MB ML320
bimmerdriver Offline
Loc: British Columbia, Canada
I have a 2002 ML320. I've put 30k kms on it. (Currently 98k kms on the odometer.) For the first oil change after I purchased it, I put in Amsoil AFL, which they are now calling mid-saps. (I realize the vehicle does not call for oil meeting MB 229.51, but I had some of this oil for another vehicle, so I used it.) I used an OEM synthetic oil filter. Also, not long after I purchased the vehicle, the rear main seal started leaking and eventually got bad enough to require replacement. I ran the AFL oil for two oil change intervals. For the most recent oil change that was done after the rear main seal was changed, I put in Amsoil EFM which they are calling full-saps. Initially, with the leaking rear main seal, I couldn't tell if the vehicle was using oil (as opposed to leaking it), but lately, with the real main seal fixed, it appears to be using oil, approximately 1 l per 1000 km, which in my opinion is excessive. Is it possible using AFL instead of EFM could have contributed to oil consumption?
2002 BMW M3 (mine)
1997 BMW 328is (sold)
2002 MB ML320 (hers)
2004 VW GTI (son)
#3442283 - 07/31/14 10:01 PM Re: Amsoil AFL or EFM for 2002 MB ML320 [Re: bimmerdriver]
brandini Offline
Loc: Richmond, VA
no
07 Mazda3s Hatch - ZoomZoom - Using EAO-ALM-BF3-MTG-ANT-ATF
#3445884 - 08/04/14 05:12 PM Re: Amsoil AFL or EFM for 2002 MB ML320 [Re: bimmerdriver]
BrianC Offline
Loc: Central Florida
Did you you change spark plugs? Are the recessed? If so, did you ensure ALL debris was removed PRIOR to removing plugs? IF not, you may have allowed dirt,sand, etc,. to fall into the combustion chamber, consequently scoring the cylinder walls.
'14 Santa Fe Sport 2.4L
#3446273 - 08/05/14 01:34 AM Re: Amsoil AFL or EFM for 2002 MB ML320 [Re: BrianC]
I did change the spark plugs (all 12), but I used a compressor to blow around them first. The engine is quite clean, so I don't think any debris got into the cylinders. I have heard that these engines can require valve seals.
2002 BMW M3 (mine)
2004 VW GTI (son)
#3450630 - 08/09/14 02:22 PM Re: Amsoil AFL or EFM for 2002 MB ML320 [Re: bimmerdriver]
I talked to a mechanic who works on MBs and other German cars. He contacted an MB service technician who said there is well-known problem with these engines where scoring occurs on the thrust side of the even numbered cylinders, usually cylinder 2 or 4. They recommend looking in the cylinders with a borescope to see if there is scoring. I don't have a borescope, but I did save some oil to send to blackstone for analysis.
2002 BMW M3 (mine)
2004 VW GTI (son)
