Originally Posted By: bionictony
I have a lot of Pennzoil ultra 5w-30 syn motor oil. I know 0w-20 is recommended for this engine. Using thicker oil will reduce MPG also. Will it be OK to use this? I'm going to do my first oil change at 5K and have the dealer do it at 10K. I know syn oil can go for longer but I live in the city a good mix of highway and stop and go traffic. Should I do the first oil change sooner? I also picked up a 12 pack of cartridges from Toyota for $51.
All i can add to this is that in Germany where no CAFE exist xw20w is only for Hybrids.
The point about CAFE is valid because the manufacturer has to recommend the oil that was used to obtain the numbers hence the wording must be changed back to 0w20.
0w30 and 5w30 is considered the optimal oil for the engine. Germany has hot summers and cold winters, city and highway driving.
They can also get 0w20 with not problem so its not like it isn't produced or sold there.
The engines are not different.
Here is Toyota list of TGMO oils currently available. The 5w30 has "Von Toyota für alle Motoren empfohlen" recommended for all Toyota engines.
http://www.toyota-bocholt.de/userdata/9001/files/2696_oel_060612.pdf
I run Euro spec 5w30 and 0w40 in Honda engines spec for 5w20 with no problem whatsoever and some of these engines have been running on it for almost 100K.
I do have a specific reason for running it, it has to do with an issue on one particular engine, not just for fun.
I would run the PU and not think twice about it.
