Had this set for 20K miles and they're smooth and getting great wear but are noisy. Most is road whine but one (or possibly two) has a low droning sound that sets in around 60+. It's more noticeable on smoother asphalt than other roads and it's intermittent....comes and goes. There's some minor feathering, too. To this point, the car (02 Camry w/145K) has had four wheel alignment twice; tires rotated three times and balanced twice. The front struts were replaced prior to buying the tires. We run 30psi in all 4. Previous sets of Summits were quiet and smooth.
Is this a tire, bearing or suspension issue? Suggestions? Help?
