I'm going to start with a little vehicle history. The vehicle is a 2002 Chevrolet Monte Carlo SS. 174k miles. I am the second owner, my aunt was the first. I got the car with 118k. When I purchased it, the engine had a slight rod knock. I knew the engine was going to fail just a matter of time. Unfortunately at 174k the engine did fail.
Suffered from catastrophic bearing failure. For those 56k miles I drove it I used Mobil 1 EP 10W30/K&N Filter or Amsoil Signature Series 10W30/Amsoil Filter. 5K OCI.
With the new engine I am starting out fresh and on the fence on what kind and type of oil I should be using.
After break in process should I go back to my 5K OCI habit with the same oil or use conventional and a 3K OCI?
I'm open for suggestions.
