Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
New router?
by Quattro Pete
08/27/16 08:44 PM
MPV 7100 Hybrid Mower
by spk2000
08/27/16 08:17 PM
Carlson Slide Pins
by SavagePatch
08/27/16 08:07 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
52 registered (3800Series, A310, B320i, 69GTX, Astro14, 901Memphis, 6 invisible), 934 Guests and 33 Spiders online.
58943 Members
66 Forums
253655 Topics
Page 8 of 10 < 1 2 ... 6 7 8 9 10 >
#3427717 - 07/17/14 04:32 PM Re: New To BMW and Synthetics [Re: OVERKILL]
yvon_la Offline
Loc: quebec canada
Originally Posted By: yvon_la
Was reading the article here on viscosity ,and gees the chart they supplied is an eye opener.a 0w40 or the one step down 5w30 if i aint mistaken have a diff of .3 (sae)2.9 for 0w40 and 2.6 for the 5w30 so basicly they re very close at 150 degree.true an oil maker would benefit huge cred by having it as close to the 100 f value as the hths article (from here but for some reason i cant find on this site.)the higher the hths the better (as close to the 100 as possible the article seems to mean
Depends on the purpose of the lubes. GF-5 5w-30 are around 3.0cp for HTHS, the "euro oils" like M1 0w-40, GC 0w-30, BMW 5w-30...etc all have an HTHS >=3.5cP. M1 0w-40 is 3.8cP IIRC.
The ACEA specs that these oils meet (except the BMW 5w-30, which doesn't officially carry the ACEA spec) calls for a minimum HTHS of 3.5cP.
are big rig oil (like cj-4 or acea 9 stuck with low hths value also ?
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3427720 - 07/17/14 04:36 PM Re: New To BMW and Synthetics [Re: yvon_la]
OVERKILL Offline
Loc: Ontario, Canada
No, only the energy conserving oils have the lower HTHS values (this is easily gleaned by just looking at the spec sheets of the oils you are thinking about). Most HDEO's have even higher HTHS's:
Mobil 1 Turbo Diesel Truck:
http://www.mobil.com/Canada-English/Lubes/PDS/IOCAENPVLMOMobil1_Turbo_Diesel_Truck_5W-40.aspx
HTHS of 3.8cP (same as M1 0w-40).
Mobil Delvac 1300 15w-40:
http://www.mobil.com/Canada-English/Lubes/PDS/IOCAENCVLMOMobil_Delvac_1300_Super.aspx
HTHS of 4.3cp
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3427725 - 07/17/14 04:44 PM Re: New To BMW and Synthetics [Re: camrydriver111]
yvon_la Offline
Loc: quebec canada
So technicly a customer could buy say a:valvoline synpower 0w20 with a hths of 8.9(or similar to what the 100 f value is?but it wouldnt be sn/energy conserving,it would be SN
Truck driver
#3427735 - 07/17/14 04:51 PM Re: New To BMW and Synthetics [Re: yvon_la]
OVERKILL Offline
The HTHS of synpower 0w-20 is like 2.6cP. You are looking at the visc at 100C figure.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3427741 - 07/17/14 04:55 PM Re: New To BMW and Synthetics [Re: OVERKILL]
yvon_la Offline
Loc: quebec canada
humor me please (in theory if it was made it would be a sn oil but not energy conserving right?)
Truck driver
#3427748 - 07/17/14 05:03 PM Re: New To BMW and Synthetics [Re: yvon_la]
OVERKILL Offline
Visc @ 100 is completely different than the HTHS visc, which is measured under high temp/high shear conditions. They are completely different measures. You cannot make a 0w-20 with an HTHS of 8.9, heck the HTHS of Redline's 10w-60 is "only" 5.8cP:
http://www.redlineoil.com/product.aspx?pid=130&pcid=21
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3428335 - 07/18/14 09:34 AM Re: New To BMW and Synthetics [Re: yvon_la]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Was reading the article here on viscosity ,and gees the chart they supplied is an eye opener.a 0w40 or the one step down 5w30 if i aint mistaken have a diff of .3 (sae)2.9 for 0w40 and 2.6 for the 5w30 so basicly they re very close at 150 degree.true an oil maker would benefit huge cred by having it as close to the 100 f value as the hths article (from here but for some reason i cant find on this site.)the higher the hths the better (as close to the 100 as possible the article seems to mean.sadly those hths value were likely the max .
Read a newer version of SAE J300. Those numbers you have are obsolete. 3.5 is the minimum HTHS for 0w-40, 5w-40, and 10w-40, with 3.7 the minimum for 15w-40, 20w-40, 25w-40, and SAE 40. Your older numbers are one reason why 10w-40 wasn't specified for as high temperatures as was 15w-40 in these German cars.
Also, read CJ-4 and the relevant ACEA E specifications. You're not going to find an HDEO meeting any of those specifications with an HTHS of under 3.5.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3434858 - 07/24/14 10:55 PM Re: New To BMW and Synthetics [Re: Quattro Pete]
bimmerdriver Offline
Loc: British Columbia, Canada
Originally Posted By: riggaz
At -30 the wind chill on his diff and sump @ 70mph will be very, very bad
Based on what I've read before, machines do not feel wind chill. Wind chill is a term invented by meteorologist in relation to how human skin/body perceives a combination of temperature and wind.
I haven't read all the way to the end, but wind chill is not a "perception". It's basic thermodynamics. The more air that moves over a body, the greater the heat transfer. Wind chill does not mean that the temperature is colder than the thermometer. It means the rate of cooling is "as if" the thermometer is at the wind chill temperature. This is why frostbite is more likely in windy conditions or when doing activities like snowmobiling in very cold temperatures. Frostbite is not a "perception", it's a very real condition. If you've ever gone skiing or snowmobiling in cold conditions (e.g., -30 or colder), you would know this.
Edited by bimmerdriver (07/24/14 11:00 PM)
2002 BMW M3 (mine)
1997 BMW 328is (sold)
2002 MB ML320 (hers)
2004 VW GTI (son)
#3435690 - 07/25/14 07:31 PM Re: New To BMW and Synthetics [Re: camrydriver111]
Shannow Offline
Loc: Oz
bimmerdriver, it's not the volume of air passing something, it's the fact that we are wet sacks of meat, and water evaporates from our surface, extracting heat in addition to that moved away via convection.
If a machine is moving through the air at a dry bulb temperature of -30F, then the coldest that it can become is -30F, no matter how much air flows over it.
A wet sack of meat (or burlap bag, or washing on a clothes line) can go much lower than the dry bulb temperature as moisture evaporates from the surface...in low humidity, the wet bulb can be a LOT lower than the dry...that's what we perceive as wind chill...it's real, but machines (unless designed with evaporative cooling) don't feel it.
#3435791 - 07/25/14 09:01 PM Re: New To BMW and Synthetics [Re: Shannow]
Read what I said. The wind chill temperature is not colder than the thermometer, but the rate of cooling down to that temperature is more rapid than it would be with no wind chill. If you heat an object and let it cool in still air, it will take longer to cool than if the air is moving. Do you think blowing on food to cool it off is just a placebo? The effect you are talking about is not the same as wind chill.
Edited by bimmerdriver (07/25/14 09:02 PM)
2002 BMW M3 (mine)
2004 VW GTI (son)
#3435894 - 07/25/14 10:40 PM Re: New To BMW and Synthetics [Re: bimmerdriver]
OVERKILL Offline
Wind chill is referenced as a temperature colder than ambient though. That's why the weather network lists both, ie, it is -25, -34 with the wind chill. It isn't just the increase in heat loss but also the body's attempt to try and deal with the heat loss which ultimately just results in more heat loss, exasperating the problem.
So while the rate of cooling increase is a real phenomenon, the referenced "wind chill" temperature is still always listed as "perceived".
I think this aligns somewhat with what you were saying.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3435908 - 07/25/14 11:01 PM Re: New To BMW and Synthetics [Re: camrydriver111]
Shannow Offline
Loc: Oz
If the statement is that convective heat transfer increases with the speed of the wind over it, then it's perfectly correct...except that's NOT chill.
Car doesn't care whether it's moving or it's wind, but a diff filled with water at running through an ambient of zero C is not going to freeze, regardless of how fast it's going...a person, animal, or the fork full of wet food will experience another, latent heat effect.
#3437782 - 07/27/14 08:20 PM Re: New To BMW and Synthetics [Re: OVERKILL]
For what it's worth, according to Wikipedia, "Wind-chill or windchill, (popularly wind chill factor) is the perceived decrease in air temperature felt by the body on exposed skin due to the flow of air." This has nothing to do with latent heat due to evaporation of moisture. It also has nothing to do with heat index or humidex, which is the perceived difference in temperature due to the humidity.
2002 BMW M3 (mine)
2004 VW GTI (son)
#3437788 - 07/27/14 08:25 PM Re: New To BMW and Synthetics [Re: bimmerdriver]
Quattro Pete Offline
Loc: Great Lakes
OK, so what was wrong with the statement I made earlier?
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3437804 - 07/27/14 08:37 PM Re: New To BMW and Synthetics [Re: Quattro Pete]
If you're asking whether it's correct to state that wind-chill only applies to humans, then you're incorrect. Wind-chill applies to any object. It is not caused by latent heat of evaporation. That is a completely different physical effect. It's also different from heat-index, which is related to humidity.
Here is the explanation of wind-chill from Wikipedia:
A solid surface loses heat through evaporation, conduction, and radiation.[1] The rate of conduction depends on the difference in temperature between the surface and its surroundings. As conduction from a warm surface heats the air around it, an insulating boundary layer of warm air forms against the surface. Moving air disrupts this boundary layer, or epiclimate, allowing for cooler air to replace the warm air against the surface. The faster the wind speed, the more readily the surface cools.
The effect of wind chill is to increase the rate of heat loss and reduce any warmer objects to the ambient temperature more quickly. It cannot, however, reduce the temperature of these objects below the ambient temperature, no matter how great the wind velocity.
2002 BMW M3 (mine)
2004 VW GTI (son)
