Originally Posted By: FetchFar
Originally Posted By: dnewton3
Where's the credible documented proof that any of this
https://bobistheoilguy.com/forums/images/markup_panel/default/bigger.gifmatters?
Where's the credible documented proof that using a "better" filter assures "better" protection to a degree that is discernable in wear data?
Here is the list of evidence (choose to believe or not) which makes one think a few extra bucks on a superior 4548-12 oil filter is worth it:
1. SAE Study
http://papers.sae.org/881825/ also cited
http://www.amsoil.com/techservicesbullet...gine%20wear.pdf
This Amsoil paper is based upon the GM filter study of 1988.
That filter study is GROSSLY misunderstood, and GROSSLY biased. It's been discussed here before. Anyone who puts faith in that SAE study knows nothing of filtration. Search the topic here and read my comments; too numerous to relate in this response. It's so non-applicable that even GM noted in the study that one would never see these kind of results in the real world; they acknowledge that their results are atypical because such disparity between filters cannot be seen in normal use. And therefore the regurgitation of GMs data in Amsoil's paper is just as worthless.
2. Observations of the engineering trend that more modern vehicles specify better filtering,... i.e, early engine designs (
Filtration is certainly "better" than in 1950, but it's peaked for many reasons. And not the least of which are that engines run far cleaner than ever before, and lubes control contamination far better than before. That you have to comment using examples from DECADES ago is how little you understand the topic in today's concept. My comments are based on the topic herein (the FU and Wix) and how they do nothing special for anyone who's running a normal OCI in today's world with today's products. Congrats on pointing out the obvious; we're not in 1925 or 1950. I would counter with this general observation; filters are getting smaller and being used longer by the OEMs. Why? Because the contaminatino loading is becoming ever less. The relevance of the filter is actually diminishing somewhat. IN NO WAY am I saying it's obsolete or useless, but I am noting that your example is actually working backwards now; filters have less of an impact than before.
3. Articles like
http://www.machinerylubrication.com/Read/29114/dirt-holding-capacity and others similar, point to how reducing grit inside an engine or machine helps reduce wear.
I would certainly agree; reducing contamination helps. But there is a law of diminishing returns here ... No one "needs" super-duper filtration for a 5k mile OCI. Capcity is only an issue if you run your normal filter to a point where it would be in bypass. I have successfully run a Puro Classic out to 10k miles and a M/C FL400 out to 15k miles in long OCIs, with dino oil, and upon dissection of the filter, everything waas fine and there was zero evidence of any overloading of the media. If they have that kind of capacity, then just where do you think the FU would have an advantage? Conceptually, no product can ever have an advantage of capacity if the original is not "full". If your OCI produces a 6 quart dump, and you have a 10 quart pan, then buying a 15 quart pan does not make for a "better" OCI change when the first pan still has excess capacity. This is the great fallacy of "more" capacity. Having a filter that hold more dirt is ONLY helpful if you run some other filter past its limit, where "more" actually occurs! I have proven that normal products already have large excess capacity; why do you need "more" when the present already has "more than enough" for a typical OCI? I'ev done it; I can prove it. Conceptually, can you prove that "more" capacity is "better" when the original is never fully used anyway? I see no ability of you to counter this concept. But by all means, try ...
4. Seeing Free Abrasive Lapping, as a machining process, produce wear.
Again - what's this have to do with normal OCIs and normal filter use?
5. Accounts of 40,000 mile oil change intervals like
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3399277/Amsoil_0W-30_41K_OCI_w/bypass_ using a synthetic & better filtration.
I agree here; longer OCI are where high-end filters and oils pay off typically. If you have never read my statements as such, then you don't visit here often.
6. Accounts of fleet benefits from 3-micron-level oil filtering ( i.e,
http://www.machinerylubrication.com/Read...er-in-fleet-ops and
http://fleetowner.com/equipment/news/california-city-fleet-oil-filters-0701 to cite just a couple.
Again - longer OCIs will benefit. Agreed. But that's not "normal" use now, is it? Fleet ops does not represent normal BITOG behavior at all ... And this little link you posted up says ZILCH to how this may or may not be able to reduce wear. This link touts the experiment of LONGER OCIs. Duh - I agree with this.
7. & Finally, I don't know of anyone who wants
more particles running around inside their engines, certainly not these guys:
http://longitudediscovery.com/TheGreatMobilHoax/index.htm
Conclusion: A few extra bucks is worth it, and
no evidence suggests that less filtering is better. For example, MicroGard MGL57090 is $5, Fram ToughGuard TG8765 $10, not much diff in price, better ISO 4548-12 performance (80% vs. 99% @ 20m).
Conclusion:
You've put forth no real credible data that shows premium filtration makes a hoot worth of difference past decent normal products, in normal use. And that's what we're talking about here.
The Fram and perhaps the Wix would likely filter to any level for a longer duration, because they are made to hold more. But that is not "better" filtration; it's filtration for "longer" periods.
Show me WEAR DATA evidence that conclusively shows normal products cannot provide the same performance as premium product in normal use! Guess what - you cannot. And why? Because there is no data to support such a conclusion; I would know, because Jim Allen and I looked for many months and found zilch.
Again - my challenge to anyone here is to show me conclusive data from a credible study that shows normal products can be usurped by premium products all while in normal use. I completely agree that bypass filtration is a means to longer OCIs, and so are products like the FU and such, but those same products do NOTHING for wear reduction in normal use.
Look over the Duramax engine data in my "Normalcy" article, and see the UOAs posted here of my truck and another. That is good data to back up my claim. And I have yet to see data to the contrary.
Here's the main bug I have in my shorts ...
Folks here do a really poor job of defining what they talk about, and what it means to them. The word "better" is thrown about like it's candy at Halloween.
Don't confuse the word "Better" with the word "Longer".
I fully agree that premium filtration can produce excellent results for LONGER periods of exposure. But if the OCI is a set max, well within normal use, then there is ABSOLUTELY ZERO PROOF THAT I HAVE EVER FOUND TO EXHIBIT THAT PREMIUM FILTERS RESULT IN LESS WEAR IN NORMAL CIRCUMSTANCES. PERIOD.
Once "good enough" is established by a filter, then having "more" does not produce "better" results.
So again, I ask for someone to put forth credible data that would counter my statements.
