Why Measure Trans. Fluid with Engine Running?
by doitmyself
05/04/16 07:39 AM
Is Pennzoil discontinuing High Mileage 10W40?
by aquariuscsm
05/04/16 06:55 AM
Lowering vehicle with alternative coil springs
by OlDirty
05/04/16 06:22 AM
Remington R1 1911 or Springfield 1911-A1 MIL-SPEC
by MuzzleFlash40
05/04/16 06:02 AM
2017 Ford F150 3.5 EcoBoost
by DuckRyder
05/04/16 05:25 AM
Ford Powershift Gearbox Class Action (Oz)
by hpb
05/04/16 03:50 AM
Central Mississippi automotive goods
by mjoekingz28
05/04/16 02:11 AM
Free: 5 Quart jug Peak 5W-30
by Indyvwhonda
05/04/16 01:01 AM
Subaru Oil Burning Class Action
by Bandito440
05/03/16 11:43 PM
'01 Toyota 3.0: oil to clean up sludge?
by HawkeyeScott
05/03/16 11:06 PM
What is the purpose of a 4.4 litre oil container?
by vitez
05/03/16 10:56 PM
Cut Open: Nissan OEM, Bosch D3300 & Mobil M1-110
by davison0976
05/03/16 10:38 PM
Palmer, jessanmark16, danbee, PTT, greasy_knuckles5
57790 Registered Users
98 registered (ARCOgraphite, 2009Edge, 87sammy, 06AllAmerican, aquariuscsm, 2015_PSD, 9 invisible), 1412 Guests and 296 Spiders online.
57790 Members
66 Forums
248443 Topics
Page 1 of 8 1 2 3 4 5 6 7 8 >
#3400852 - 06/18/14 07:01 PM Where's the documented proof ?
Merkava_4 Offline
Loc: Clovis, CA
Where's the documented proof that the FRAM Ultra is 100% efficient at 20 microns ?
Where's the documented proof that the WIX XP is 50% efficient at 20 microns ?
Let's get down to the nitty-gritty !
#3400857 - 06/18/14 07:04 PM Re: Where's the documented proof ? [Re: Merkava_4]
MolaKule Offline
Loc: Iowegia - USA
Whoaa! Is the smog getting real thick in Clovis? grin2
My wild oats have turned into shredded Wheat. smile
#3400866 - 06/18/14 07:12 PM Re: Where's the documented proof ? [Re: Merkava_4]
jhellwig Online   content
Loc: Ottumwa, Iowa
Go google it yourself.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2013 Chevy Traverse lt 3.6l direct injection
1983 Chevy K5 350
#3400868 - 06/18/14 07:14 PM Re: Where's the documented proof ? [Re: Merkava_4]
SatinSilver Offline
Loc: Ohio
popcorn2
2012 Toyota Camry 60k miles- PP 0w20, oem filter (TGMO all prior)
2005 Toyota Matrix 98k miles- MC 0w20 syn-blend, MC filter
#3400878 - 06/18/14 07:21 PM Re: Where's the documented proof ? [Re: Merkava_4]
901Memphis Offline
Loc: Northern Kentucky
First off your information is incorrect. Fram lists their Ultra at 99%+ efficient at 20 microns based on ISO 4548-12 for particles > 20 microns.
http://www.fram.com/oil-filters/fram-ultra-synthetic-oil-filter.aspx
Second the Wix doesn't test under ISO 4548-12 but lists a beta ratio which is expressed at 50% @ 20 microns.
Wix simply may not care to test their filter or publish it properly.
If the numbers are true it's most likely based on the fact that Wix uses 1 layer of synthetic media, while FU uses two layers, so its more efficient from the get go.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3400882 - 06/18/14 07:26 PM Re: Where's the documented proof ? [Re: 901Memphis]
ZeeOSix Offline
Loc: PNW
It's true they don't reference what test spec their beta ratios are based on ... at least not on their website. They could use ISO 4548-12. Has anyone called their Tech Dept and ask what test spec they base their beta ratios on?
#3400885 - 06/18/14 07:27 PM Re: Where's the documented proof ? [Re: 901Memphis]
ZeeOSix Offline
Loc: PNW
99%+ filtration efficiency2
Yep ... per flag note 2:
"2 FRAM Group testing of average filter efficiency and dirt holding capacity using FRAM XG3387A, XG8A, and XG4967 and their leading economy filter model equivalents under ISO 4548-12 for particles > 20 microns."
#3400900 - 06/18/14 07:44 PM Re: Where's the documented proof ? [Re: Merkava_4]
steveh Offline
Loc: wisconsin
Fram is only listing efficiency on 3 part numbers.
#3400904 - 06/18/14 07:48 PM Re: Where's the documented proof ? [Re: ZeeOSix]
Merkava_4 Offline
Loc: Clovis, CA
With all due respect and in the interest of complete politeness, that don't prove nothing to me.
Nadda, zilch, zippo.
#3400905 - 06/18/14 07:49 PM Re: Where's the documented proof ? [Re: steveh]
ZeeOSix Offline
Loc: PNW
Better than Purolator that just references their largest oil filter for the ISO test (L/PL/PSL 30001).
If you look at the sizes of those 3 filters that Fram references, they pretty much cover the small to large range of filters.
#3400915 - 06/18/14 08:08 PM Re: Where's the documented proof ? [Re: ZeeOSix]
2015_PSD Online   content
Loc: SE Texas
Better than Purolator that just references their largest oil filter for the ISO test (L/PL/PSL 30001). If you look at the sizes of those 3 filters that Fram references, they pretty much cover the small to large range of filters.
+1 - rather than show all of them, it would **seem** they covered the range to show that no matter what size filter is chosen they have similar ratings. Puro's 14610 always dug under my skin a little (it fits my BF750); the 14610 is 99.9% efficient at 40 microns, but a similar filter, the 14459 is 99.9% efficient at 20 microns.
Why the urgent need for "documented proof"? You do not use oil or filters long enough to warrant the slightest concern...
2015 F-250 PSD.................Kendall 15W-40 CJ-4 + CQ
2014 Explorer LTD.............PUP 5W-20 SN + FU
2010 Kawasaki BF750 4x4....RT6 5W-40 + OEM
#3400925 - 06/18/14 08:15 PM Re: Where's the documented proof ? [Re: 901Memphis]
earlyre Offline
Loc: Lima, Ohio, USA
...If the numbers are true it's most likely based on the fact that Wix uses 1 layer of synthetic media, while FU uses two layers, so its more efficient from the get go.
I think you just talked me into giving Fram Ultra's a try, if for no reason other than it never clicked in my head that Fram Ultra would be abbreviated as F.U!
I can just see it in my sig now, "2009 Mercury Sable PP 5-w20, FU3600"
...though I Guess that's why they used the XG part numbers.(yes I know it'd actually be an XG3600, but that's not as funny)
Edited by earlyre (06/18/14 08:27 PM)
Mine:
09 Mercury Sable : 6qts QSAD 5w20,WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts QSAD 5w30,WIX 51394
#3400926 - 06/18/14 08:17 PM Re: Where's the documented proof ? [Re: Merkava_4]
Rand Offline
Loc: NE,Ohio
Hes high on smog and came to bitog to troll today? not sure.
Not sure why he is suddenly demanding proof in such a Troll-lololol fashion otherwise. If its that important phone fram and ask them.
No one here works for them. We can only go by their published information.
2015 Forester I-Premium 6MT
#3400927 - 06/18/14 08:18 PM Re: Where's the documented proof ? [Re: Merkava_4]
KCJeep Offline
Loc: Mahzurrah!
Well that's the test they all use, at least the ones that bother anyway, so if that's not good enough you'll need to invent your own test. Have at it, and be sure to provide us all some "documented proof" while your at it.
Or: (My alternate post)
You are just trolling. trolling
2004 Jeep Grand 4.0 @ 132k Pennzoil HM 5w30 w/ 1 qt 10w40
Fram TG8A
KIA Sedona 57k, Ford Focus 114k, Chrysler Sebring 184k, Chrysler Concorde 115k
#3400930 - 06/18/14 08:25 PM Re: Where's the documented proof ? [Re: Merkava_4]
901Memphis Offline
Documented proof? How about all the amazing used oil analysis that use Fram Ultras?
Trace
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3322851/2006_Toyota_Sequoia,_M1_5w-30,
