Round holes AND louvers! Oh the humanity!
by Nick1994
36 minutes 44 seconds ago
Should I change the oil when changing spark plugs?
by THafeez
48 minutes 53 seconds ago
Maxima synthetic oil
by gman2304
54 minutes 26 seconds ago
Mobil vs. Castrol: Battle of the Walmart 0W-40s
by 1JZ_E46
58 minutes 11 seconds ago
Need advice for older car burning too much oil
by Car_Careguy
Today at 03:29 PM
Camaro 2.0T review by subaruwrxfan
by wemay
Today at 03:18 PM
Dryer Duct Boosters?
by 2015_PSD
Today at 03:02 PM
some strange lawsuits against fast food franchises
by John_Conrad
Today at 02:40 PM
Rotella T5 10W-30 in Chevy Z71
by RHALL
Today at 02:20 PM
Multigrade Oils in Mowers
by camrydriver111
Today at 01:59 PM
Is this GM executive serious ? Or he's a moron ?
by HTSS_TR
Today at 01:40 PM
My UOA with Frantz TP Filter
by Jonzobot
Today at 12:43 PM
ryaneirich, Gabe78, taters, Louis_Desbiens, Burk
58918 Registered Users
88 registered (1JZ_E46, 97f150, 007, 2015_PSD, 390pi, addyguy, 9 invisible), 1836 Guests and 6 Spiders online.
58918 Members
66 Forums
253549 Topics
Page 2 of 2 < 1 2
#3399282 - 06/16/14 08:38 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
cpayne5 Offline
Loc: Virginia
How about a little teflon tape? A couple wraps around the swaybar keeps the poly bushings on my TSX quiet.
wouldnt the teflon tape shred away in a matter of days?
I agree that no grease is best...but too late now. I will probably end up buying two new oem bushingsf or 5 each.
No, it will last quite a while, and costs next to nothing.
I will give this a shot tonight and report back. Did you apply any lube?
It's an aftermarket swaybar. It originally came with teflon grease (poly bushings), which lasted about two years before it became squeaky. I lived with the squeaks for about a year, then this past winter (once I installed the lift in my garage grin) wrapped the swaybar with teflon tape where the bushings engage (no additional grease). No squeaks so far after about 6 months. I've put about 15k miles on it in that time.
Edited by cpayne5 (06/16/14 08:41 PM)
#3399413 - 06/16/14 11:29 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
garlicbreadman Offline
Loc: USA
I added teflon to the my rear sway bar and its whisper quiet now! Hope this last a while! Thanks all for your recommendations!
I also have a tsx(gave to sister) and i put a progressive rear sway bar on it and it is also squeaking. I will add teflon tape to it when i get a chance.
#3401912 - 06/19/14 11:52 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
MCompact Offline
Loc: KY
I just bought a JBR rear bar for the MS3, it comes with polyurethane bushings and brackets equipped zerk fittings. The grease they provide for installation is Super Lube NLGI Grade 2.
Mine:
2014 M235i
1999 Wrangler Sahara
1995 318ti Club Sport
1996 Speed Triple
Wife's:
2004 X3 2.5i
Son's
2009 328i
Buy what makes you smile...
#3402251 - 06/20/14 01:06 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
Quest Offline
Loc: beaver land EH?
When I replaced my 323 sway bar bracket bushings with EnergySuspension polys, they came with some very tacky/sticky silicon grease pack. I used them in my sway bar bushings (only used once during installation, no re-lubing afterwards) and they lasted for years w/o squeaking at all.
My sway bar also has paint coated on the area where the bar meets the bushings, never an issue.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3402393 - 06/20/14 04:44 PM Re: What grease for sway bar bushings? [Re: MCompact]
dailydriver Offline
Loc: Bucks County, Pa.
That is exactly what UMI suggests for their Roto-Joint type rod ends as well. wink
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3402395 - 06/20/14 04:46 PM Re: What grease for sway bar bushings? [Re: Quest]
dailydriver Offline
That is the viscous stuff made by (or for) Prothane and Energy Suspensions.
It is even made in 14 ounce grease gun cartridges as well, if you want to pay the coin for it.
M1-206 oil filter
#3402447 - 06/20/14 06:24 PM Re: What grease for sway bar bushings? [Re: dailydriver]
aquartlow Offline
Loc: Florida
I have had good luck using an anti seize lubricant like "Never Seez" on both my front and back sway bar bushings. If you have ever got some on your fingers you already know it will stay on the bushing/sway bar surface. Todd
#3456050 - 08/15/14 06:15 AM Re: What grease for sway bar bushings? [Re: garlicbreadman]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
I've always just used Sil-Glyde and never had a problem.
2007 Lincoln Navigator M1 0w-40/FU
1968 Charger R/T / Supercharged 440 VR1/DBL7349
2007 Ram 3500 4x4 / Cummins 6.7 /DBL7349
2015 Porsche 911 C4S PDK
#3464302 - 08/25/14 08:16 AM Re: What grease for sway bar bushings? [Re: garlicbreadman]
ac_tc Offline
Loc: sweden
Remember to do the final tightening with the suspension loaded.
This applies to all loaded bushings in the suspension.
-98 Dodge Durango 5.9 4*4 HDEO 10w- 40 ci4
-04 PT Cruser GT 10w- 40 HDEO ci4
-Everything else HDEO 10w- 40 ci4/STOU 10w-30/THF
#3466342 - 08/27/14 01:08 PM Re: What grease for sway bar bushings? [Re: garlicbreadman]
Nayov Offline
Loc: ME
I used leftover silicone RTV (gasket maker, etc) as a lube on the sway bar bushing end links (Nissan) because I'm too cheap to buy silicone grease, but it seems to be working as the noise is gone.
#3478183 - 09/09/14 09:16 AM Re: What grease for sway bar bushings? [Re: Doog]
Bgallagher Offline
Loc: Boston, MA
Originally Posted By: Doog
The best lube is no lube.
+1 Why don't you just replace the bushing or the whole sway bar for that matter? You can get either pretty cheap at rockauto. You are only prolonging the inevitable if you're greasing bushings. Or try moving back to regular rubber bushings.
Edited by Bgallagher (09/09/14 09:17 AM)
2005 Chevy Equinox - 137k -Penn. HM/AC PF52 (non e-core)
2005 Chevy Malibu - 167k - Penn. HM/AC PF457G
2015 GMC Terrain - 5.3k- Delco Dexos 1 and PF457G
#3478836 - 09/10/14 12:15 AM Re: What grease for sway bar bushings? [Re: garlicbreadman]
Loc: USA
Teflon tape is holding up well, thank you for the suggestions!
Page 2 of 2 < 1 2
