Wix coolant filter change and cut open
by A310
05/31/16 03:45 AM
O2 Sensor Voltage
by Falcon_LS
05/31/16 01:36 AM
Electrical shock at the grocery store
by Merkava_4
05/30/16 11:42 PM
Another should I change my oil thread
by dan_erickson
05/30/16 10:53 PM
new HDM part number for lacrosse headlamp recall
by lucerne06
05/30/16 08:48 PM
snapper blade control is stiff
by edwardh1
05/30/16 08:44 PM
is my extension cord bad?
by motor_oil_madman
05/30/16 08:33 PM
Done with Sandisk USB Sticks
by JHZR2
05/30/16 08:20 PM
Pineapple Margaritas
by sleddriver
05/30/16 08:12 PM
Replacing Drywall In The Bathroom (Insulation)
by Warstud
05/30/16 07:56 PM
351W build with a flat tappet
by ssregal39
05/30/16 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
05/30/16 07:12 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
31 registered (bourne, chrisri, ActionJoe, BigD1, czbrian, car51, 6 invisible), 514 Guests and 316 Spiders online.
58031 Members
66 Forums
249618 Topics
Page 1 of 3 1 2 3 >
#3390175 - 06/05/14 09:21 PM 2014 Jeep GC EcoDiesel 3.0 - Rotella T5
Fraser434 Offline
Loc: Chicago
Rotella T5 10W30 with half bottle 8oz of liquimoly MOS2. 4,000 miles.
Still breaking in. Taking another sample soon from T5 with no moly added, 4,000 miles.
http://www.jeepgarage.org/attachment.php?attachmentid=40620&d=1401752412
Edited by Fraser434 (06/05/14 09:24 PM)
#3390177 - 06/05/14 09:24 PM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: Fraser434]
simple_gifts Offline
Loc: Middlesex County CT
Need a login to see.
2003 Echo >390K miles; Showing its age.
2006 B2300;105K;ALM
Please conserve paper; it is not like it grows on trees.
#3390189 - 06/05/14 09:40 PM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: Fraser434]
Fraser434 Offline
Loc: Chicago
#3390190 - 06/05/14 09:41 PM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: Fraser434]
Fraser434 Offline
Loc: Chicago
Fixed!
#3390204 - 06/05/14 10:01 PM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: Fraser434]
Clevy Offline
Loc: Saskatoon canada
Not that I put much stock in wear metal counts but isn't that really low for an engine that's just breaking in.
We've seen iron counts of from 50-100 ppm on breaking on engines.
I wouldn't have used any mos2 til 10000 miles just to insure proper break in however by the looks of this and how low wear metals are I wonder in its hindered anything.
Thanks for posting.
Is this the same Diesel engine going into the ram trucks. If this is any indication they should be a long lived unit mechanically.
2006 Charger RT
Miles x 2 per oil filter
#3390232 - 06/05/14 10:43 PM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: Clevy]
Fraser434 Offline
Loc: Chicago
same engine as the ram 1500, and maserati Ghibli (UK version).
#3390235 - 06/05/14 10:50 PM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: Fraser434]
Clevy Offline
Thank you
2006 Charger RT
#3390262 - 06/05/14 11:55 PM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: Fraser434]
01_celica_gt Offline
Loc: St. Louis, MO
I thought Diesel engine can go WAY longer between oil changes? I have seen some uoa with 20k and plenty of life left with low wear metals
Red/Black 01 Celica GT 1ZZ-FED(Rebuilt @ 211/144) @ 211/145k
Red 02 Corolla S 1ZZ-FED(Rebuilt @ 140k) @ 141k
All Autos!
#3390266 - 06/05/14 11:59 PM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: Fraser434]
Fraser434 Offline
Loc: Chicago
Course it can, but i'll do short OCI's while its still breaking in. I drive 3000 miles per month, we'll get there.
Other issue is low SAPS oil, I don't trust it enough yet to stretch out an OCI. Some TDI VW/BMW i've seen had 100+ ppm iron after 10k miles, thats bad.
Edited by Fraser434 (06/06/14 12:02 AM)
#3391593 - 06/07/14 05:10 PM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: Fraser434]
RangerGress Offline
Loc: GA
Fraser, I've been watching your Ecodiesel posts for the past couple months. I have one also. Why did you choose T5 instead of T6?
I tow a 7400lb 24' enclosed trailer with my Ram. The towing capacity of my truck is 7800lb per it's VIN so I'm pretty close to it's rated capacity. On my first roadtrip 220mi each way, oil temp hit 240deg. Since that's higher then I'm used to in a car, I got to thinking along the lines of full synthetic. Why did you choose a synthetic blend instead?
#3391783 - 06/07/14 09:48 PM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: Fraser434]
Fraser434 Offline
Loc: Chicago
I prefer oils with less VI improvers, 10W30 doesn't need much, i'm finding engines burn oil typically at start up with thinner oil. I'd like the oil to be within the 30 weight viscosity, doesn't appear to need over [email protected] Later this summer i'll try Schaffer SAE30 oil.
Far as difference between T5 and T6, they call Synthetic, however I believe T6 is just a group III hydrocracked dino oil. In fall i'll try T6 when it drops below 32F.
#3392691 - 06/09/14 04:41 AM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: RangerGress]
dnewton3 Offline
Loc: Indianapolis, IN
240 degF is not too hot, even for a conventional lube; you don't "need" a syn if that is typical for your conditions. When GM did their infamous "filter" study, they held the temp at 250F for the entirety of the testing. I would get concerned if you saw sustained temps over 275F. I would not worry in the least bit if 240"ish" or less is what you're seeing.
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3395384 - 06/12/14 07:26 AM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: Fraser434]
rossn2 Offline
Loc: Ft Hood Texas area
SO, you dumped the factory fill at 3000 miles if I read the report correctly?
The Ram 1500 Ecodiesel is rated to go 10k miles between oil changes. The cartridge-style oil filter for the Ram is like $60 from the dealer.
How about the Schaeffer Supreme 7000 Synthetic Plus Engine Oil SAE 10W-30
or the Supreme 9000 in 5w-30?
I use the 7000 20w-50 in my Harley and like it a lot.
Edited by rossn2 (06/12/14 07:33 AM)
2015 Ram 1500 Crewcab Laramie, 4x4, 3.21 rear and Hemi
2016 Hyundai Tuscon ECO 4cyl (33mpg)
2015 FLHTK (Stage IV kit, 106 HP) 2013 CVO Ultra,
#3399455 - 06/17/14 01:07 AM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: rossn2]
Fraser434 Offline
Loc: Chicago
Yes dumped at 3000. I'd rather dump the factory oil early.
With Non Bio Diesel they say 10k; B5-B20 8k miles for OCI
Every diesel pump i've seen in the midwest says it could be up to B20, so realistically the EcoDiesel should be 8k OCI.
Edited by Fraser434 (06/17/14 01:08 AM)
#3406594 - 06/25/14 01:22 PM Re: 2014 Jeep GC EcoDiesel 3.0 - Rotella T5 [Re: Fraser434]
philbytx Offline
Loc: Texas, USA
So, you are still in the warranty period and you choose to ignore Chrysler's MS-11106 specified oils.
Only two oils are currently spec'd - both 5w30 - Pennzoil Ultra Euro L and Mobil1 ESP. I hope you do not experience any internal issues with your turbo motor!
Phil C.
2014 Jeep Grand Cherokee Overland CRD
2011 Kia Optima EX-P
2000 BMW R1100R
2003 BMW R1150RT
Page 1 of 3 1 2 3 >
