Yokohama AVID Acend 195/60R15. $190
by Sam_Julier
04/30/16 07:24 AM
Hate those adds that start with, "Lean 1 weird ...
by OneEyeJack
04/30/16 05:11 AM
How Much Olive Oil Do You Use?
by GrtArtiste
04/30/16 03:20 AM
Hyundai filter 26300-35503 10PK for 35.40 FREE S&H
by GumbyJarvis
04/30/16 01:10 AM
Dope smoking genius Laremy Tunsil NFL Draft Pick!
by GiveMeAVowel
04/29/16 09:50 PM
'13 Honda VFR1200 Motul 10w-50, 5,300 miles.
by montero1
04/29/16 09:35 PM
Anyone Using Spline Sockets?
by JHZR2
04/29/16 09:33 PM
Anyone Tryed Spectra Premium O2 Sensors?
by Mr_Accord
04/29/16 09:16 PM
UPS package tracking is so confusing!
by Klutch9
04/29/16 07:52 PM
Dupont non-stick lube
by buck91
04/29/16 07:47 PM
House electrical wiring question
by road_rascal
04/29/16 07:46 PM
Air pressure question
by aquariuscsm
04/29/16 07:43 PM
hdwizard21, raihan, aceracres, kg4geq, red_bulldog
57748 Registered Users
77 registered (AandPDan, AirgunSavant, Bandito440, 2002 Maxima SE, andyd, 10 invisible), 1329 Guests and 118 Spiders online.
57748 Members
66 Forums
248235 Topics
#3389853 - 06/05/14 02:57 PM Larger tire size
outoforder Offline
Loc: Ohio
Only tire size available for my 08 Focus is a 50R. The tire I want only goes as low as 55R. What would happen if I put on these tires instead of OEM?
2003 Grey Jetta TDI 304,000 miles
1999 Green Jetta TDI 353,000 miles
2002 White Expedition 168,000 miles
#3389854 - 06/05/14 02:59 PM Re: Larger tire size [Re: outoforder]
Quattro Pete Offline
Loc: Great Lakes
What is 50R?
Can you provide complete nomenclature/tire size?
'02 530i (PPE 5W-40)
'15 Q5 3.0T (Edge 5W-40)
#3389869 - 06/05/14 03:22 PM Re: Larger tire size [Re: outoforder]
Loc: Great Lakes
If it's 205/50/16, then you could potentially run 195/55/16 instead. Load index is the same, and the overall diameter would be less than 2% different from stock.
#3389873 - 06/05/14 03:25 PM Re: Larger tire size [Re: outoforder]
copcarguy Offline
Loc: PA
As stated above, you'll need the entire tire size... There is a great tire size calculator here:
http://www.miata.net/garage/tirecalc.html
You can compare your current size to another, and it'll tell you how much it'll throw off your speedometer, revolutions per mile, etc...
HTH
#3389992 - 06/05/14 05:19 PM Re: Larger tire size [Re: outoforder]
outoforder Offline
Loc: Ohio
OEM tire is 205/50R-16. The tire I want doesn't come that small. Nearest size is 205/55R-16.
#3389999 - 06/05/14 05:33 PM Re: Larger tire size [Re: outoforder]
HTSS_TR Offline
Loc: Lake Forest, CA
OEM size diameter is 24.1", 205/55-16 is 24.9" about 3.4% larger than OEM.
Is it okay with your car, hard to tell.
I tried 245/45-17 instead of OEM 235/45-17 on my E430 10-11 years ago, the ABS malfunction within 100 miles such that I had to go back to OEM size, and the ABS malfunction light went off within a mile of driving.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#3390003 - 06/05/14 05:36 PM Re: Larger tire size [Re: outoforder]
outoforder Offline
Loc: Ohio
Car is a 2008 Ford Focus. Apologies for not including all information in earlier posts. The tire guy at Sears appears knowledgeable and has no qualms about this. However, it is Sears…… :-/
Tires are currently being installed. We will know soon. I have 30 days to like them so if anything goes wrong, I can take them back.
#3390406 - 06/06/14 07:03 AM Re: Larger tire size [Re: outoforder]
CapriRacer Offline
Loc: Somewhere in the US
According to Discount tire, a 215/50R16 will fit, but they don't list the 205/55R16. That's probably because it's over 3% different in diameter. They don't like recommending anything more than that.
CapriRacer
Visit my web site: www.BarrysTireTech.com
#3390428 - 06/06/14 07:37 AM Re: Larger tire size [Re: outoforder]
outoforder Offline
Loc: Ohio
I got 205/55R-16 Hankook Road Handlers on the car. Drove 20 miles home with no issue. The vibration from previous tires is gone. I realize this is a statistically insignificant distance, but so far, so good.
#3400292 - 06/18/14 03:04 AM Re: Larger tire size [Re: outoforder]
Darris Offline
Loc: Toronto, ON. Canada
Your spedometer and odometer will be slightly off due to the computer pre-supposing a few more wheel revs per mile. Might slightly effect metrics such as instant & average fuel economy.
I recently took possession of a vehicle with larger than stock diameter. It slows it down a little off the line, and accelerating within city speeds, but takes less gas to maintain highway speed. Car seems to have more momentum and takes a little more brake to bring it to a stop. I imagine it will wear the brake pads a bit sooner than stock diameter or smaller.
Edited by Darris (06/18/14 03:04 AM)
'02 Nissan Altima 2.5L 2011-2014
'03 Nissan Altima 2.5L 2014-
#3400574 - 06/18/14 12:23 PM Re: Larger tire size [Re: outoforder]
Ken2 Offline
Loc: Washington St.
205 mm across the width of the tire body (approximate)
50% aspect ratio = width to height ratio, so the tire from bead to tread is about 52.5 mm high
R = radial
16 = wheel rim diameter in inches
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
