Hi All,
I had posted a question in the hydraulic fluids section about what oil i should put in my new 28 ton Dirty Hand log splitter and now had a question about the filter. I wanted to do it properly and ask in the filter section instead of continuing off topic there. I've read (possibly somewhere on here) what filter is used is more important then the oil used. My question is, how can i find which one will fit and what is a good filter? It has a screw on type like a car uses but didn't see a part number except for the Dirty Hand part number listed in the manual. Does it go by thread size? Physical size (length/dia)? All interchangeable? I found a post that listed Parker and Hydac with a part numbers after each as good ones, but i can't find any info if they are compatible with mine. Again, any help/thoughts would be much appreciated.
Hafiii
Hafiii
