The sliding surfaces of the brake pads ears that is. I lubed all three vehicles this fall, tide I pulled a wheel liner on the Jetta to check some corrosion, and decided to pull pads too. No grease left at all! I had used Sta-Lube, some time this fall, maybe November, and I've only driven 10k since then. The pads were not frozen but not quite loose either.
I'm guessing I need to pull the brakes on the two now also, and that I need to do this 2x a year.
