JHZR2
Staff member
Car is a 2008 Volkswagen rabbit with the 2.5 engine, takes about 5.8 quarts of oil to fill after an oil change with filter.
Did an oil change this weekend and installed Castrol edge 0W 40 because it meets the correct spec. This was the German made product. I put in the full contents of the 5 quart bottle I bought, then drove it a little bit to get an accurate assessment. Of course it looked to be about a quart low as the level was at the lower notch on the dipstick. So I added just under a quart of oil, let it sit for a little while, and it was at about the three-quarter mark. Nothing out of the ordinary in terms of how I usually fill the car after an oil change no difference. So I added a little bit more a little too much more. It was maybe 2 mm above the full point on the dipstick. Not excessively overfilled not anything to write home about really. I would imagine that many mechanics just install 6 quarts of oil on these engines to begin with and leave it that every time.
Fast forward to after a 200 or so mile drive, we get home and I noticed that on the back of the car there are a ton of little oily specs with dirt mixed in them (the car still is rather dirty from the winter).
Immediately I checked the tailpipe wondering if something went terribly wrong. Dry as could be, not the slightest indication of oil or residue of any sort.
I know I leaked a little someplace onto the engine because those edge bottles "glug" quite a bit. But there is a big shroud/cover over the engine, and a rubber ring around the filler. Everything within sight was dry.
So any thoughts on this? I would imagine that the engine is designed for someone to fill with at least six cords and then a good deal over that in terms of safety margin. I got well over five cords out I know that from when I was filling it to take it to the recycler. If I overfilled it was bad less than a half quart.
Has anyone observed oil speckling on the back of a car due to being slightly overfilled??
