Originally Posted By: sayjac
Looks good, and if the caps didn't fall off then they were still bonded. And even if they did, as long as the potting is intact (which it appears to be) and the leaf spring functioning properly (holding element), it's not a bypass issue.
At a substantial 11k mi oci, no tears, looks like it held and did it's job. Got your monies worth out of this one. Currently running same filter to a 10-15%MM oci in an Accord.
How long (time) did it take to accomplish the 11k oci?
Thanks for the pics.
Yeah, the caps did not fall off and the potting is intact as far as I can see. This is the same filter that I'm running on my Civic. I go to 15% on the MM which is usually about 7500 miles.
This is off my daughter's car. It took her 6 months to rack up the 11K.
