What would you do in my situation?
by 55Test
06/27/16 05:03 PM
fuel additives AS fuel?
by 55Test
06/27/16 04:58 PM
Best Crimping Die for SA .223?
by 2015_PSD
06/27/16 04:49 PM
Castrol Edge EP Viscosity Index
by Gene K
06/27/16 04:34 PM
Iceland beats England
by hatt
06/27/16 03:51 PM
1991 Clean Acura NSX with some mods for $45k
by HTSS_TR
06/27/16 03:16 PM
Tiny metal particles suspended in oil?
by rustypigeon
06/27/16 02:35 PM
M1 0w20, 10,093 miles, 2006 Civic
by Patman
06/27/16 02:13 PM
5w-40 synthetic vs 15w-40 synthetic
by mbacfp
06/27/16 01:27 PM
SCAM!Anyone renting their water heater tank?
by KrisZ
06/27/16 01:16 PM
Donaldson PowerCore as HEPA filter?
by PeterPolyol
06/27/16 01:13 PM
Clearance oversized filters for M20x1.5 w/bypass
by PeterPolyol
06/27/16 01:05 PM
alostaunau, alanwayne1908, scuff, Tuar, ATFD48
58292 Registered Users
77 registered (alanwayne1908, 55Test, 007, 2009Edge, Alfred_B, 2015_PSD, 5 invisible), 1953 Guests and 10 Spiders online.
58292 Members
66 Forums
250891 Topics
Page 3 of 3 < 1 2 3
#3259616 - 01/25/14 12:29 PM Re: best warm up patern in winther. [Re: shDK]
TiredTrucker Offline
Loc: Central Iowa
I suppose that if one is starting their vehicle after sitting all night and within the next few second, merging into 70 mph traffic on a freeway, then some form of warm up would be in order. But most of us have at a least a little bit of driving at a reduced speeds on streets before hitting the big road. An engine will warm up faster under moderate power than sitting at idle. After maybe a minute, mine is going to go into drive and I am going to head out. If the cold is something really blistering in the morning, the get a block heater, oil pan heater, and maybe a battery heater pad. That would be better for your engine than starting at extreme cold on it's own. These items are not that expensive, use little electrical power, can be put on a timer, and take a lot of strain off of an engine at startup in extreme cold.
In order to know what is bad, you have to know what is good. The question them becomes, what is the source of knowing what is good?
#3261481 - 01/27/14 11:52 AM Re: best warm up patern in winther. [Re: shDK]
supton Offline
Loc: NH
Heh, I found myself annoyed with myself this morning. I took the truck, but as it was warm (like 18F) I didn't bother with warming up. Coming down the hill I wasn't thinking and forced a downshift, making the truck go into fuel cutoff. After going through the light and getting up to 55mph I had to endure at least 2 miles of driving with the trans refusing to go into high gear and lockup.
Teaches me about trying to save fuel and brakes!
2011 Toyota Camry, base, 6spd manual, 116k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 126k, his
#3261491 - 01/27/14 12:04 PM Re: best warm up patern in winther. [Re: shDK]
Eddie Offline
Loc: Florida, Cape Coral
I wait till the engine comes off the fast idle before driving easy till full wanrm. Usually comes off the fast idle within 20 seconds. Ed
CX5 Touring 2.5L :-)
#3261551 - 01/27/14 01:18 PM Re: best warm up patern in winther. [Re: shDK]
D189379 Offline
Loc: Canada City, Canada
Someone should just make a sticky with all of the pros and cons of each method so this thread doesn't keep popping up.
Page 3 of 3 < 1 2 3
