SAE 16. Set at a minimum of 2.3 mPa⋅s at 150C
by wemay
14 minutes 34 seconds ago
1992 Surburban Big Block - M1 10W-30 - 5 year OCI
by bigt61
15 minutes 53 seconds ago
2007 Civic Wiper Blade Contact Fix
by 4thstpositively
33 minutes 45 seconds ago
Got me a new Stihl FS 56 trimmer today
by daddi
Today at 01:02 PM
Truck cap lights.
by wolfehunter
Today at 12:12 PM
filters and oem specs
by mobilaltima
Today at 11:50 AM
H11 bulb options
by asiancivicmaniac
Today at 11:47 AM
Engine oil accidently added into transmission
by Mazatrol
Today at 09:51 AM
Oil for 1996 Mazda B4000 pickup
by schuylkill
Today at 09:16 AM
Shell gas $80 rewards cars for $52 Deal ends 9-1
by gojoneeded
Today at 09:12 AM
Cleaning a carpet stain....Help!
by mjk
Today at 07:39 AM
Windshield: can it be repaired?
by supton
Today at 07:12 AM
pperras01, Grabberblu, Dave_PPE, davebe, Logos
58964 Registered Users
89 registered (86cutlass307, 4thstpositively, 4WD, 1foxracing, 09_GXP, 10 invisible), 1727 Guests and 8 Spiders online.
58964 Members
66 Forums
253775 Topics
Page 1 of 2 1 2 >
#3259871 - 01/25/14 05:40 PM Different size filters??
tojo1968 Offline
Loc: orlando fl
I just took advantage of an AAP deal and walked away with 10 qts of Mobil 1 5w-30 HM and 2 Mobil M1-108 oil filters (for my wifes 08 Sportage v6) for only $62! My question is this, the M1 looked kind of small so I had the guy pull a Fram, a PureOne and a K&N for comparison. The M1 and K&N were the same size, approx. 1/2" shorter in height and smaller in diameter than the P1 and Fram. The gaskets did line up with each other. The guy behind the counter said they are smaller because they are more efficient?? Mobil's website calls for the M1-108 but the obvious size difference is unnerving! I appreciate any input!
Edited by tojo1968 (01/25/14 05:42 PM)
2015 Frontier Desert Runner CC 4.0
#3259880 - 01/25/14 05:46 PM Re: Different size filters?? [Re: tojo1968]
GreeCguy Offline
Loc: Elderly County, Florida
That used to happen to me with my wife's 01 tracker. I can't remember which brand was smaller, (car gone for five years now), but the Fram was slightly bigger, (my filter wrench would fit it but would slip on the other filter).
"Dyslexics are teople poo!!."
#3259883 - 01/25/14 05:50 PM Re: Different size filters?? [Re: GreeCguy]
tojo1968 Offline
Loc: orlando fl
I have never seen this before so I want to make sure I don't screw up her beloved Sportage!
#3259891 - 01/25/14 05:58 PM Re: Different size filters?? [Re: tojo1968]
fdcg27 Offline
Loc: OH
The oil filters will be fine.
The current trend is toward ever smaller oil filters.
One reason is likely cost.
OTOH, there isn't much to filter out in a healthy engine after break-in.
Cut open an oil filter after a typical interval and see whether you can observe any debris.
There won't be any.
12 Accord LX 53K HGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 159K Delvac 15W-40
#3259902 - 01/25/14 06:09 PM Re: Different size filters?? [Re: fdcg27]
tojo1968 Offline
Loc: orlando fl
Forgive my ignorance, but will the smaller filter inhibit the flow rate and/or PSI in any way?
#3259977 - 01/25/14 07:16 PM Re: Different size filters?? [Re: tojo1968]
65f100 Offline
Loc: Oklahoma
I have noticed some smaller than standard filter lengths lately. Each of these filters is for the same application (modular ford v8)
#3260004 - 01/25/14 07:37 PM Re: Different size filters?? [Re: tojo1968]
JDW Offline
Loc: South
I wonder why the different sizes ? And if the size effects filter performance . I always run Motorcraft on this modular ,would prefer the longer case but always fine the med length ones.
Edited by JDW (01/25/14 07:38 PM)
Ford's & Wix filter's Amsoil 5W-30 SS
2014 Wix Master Tech
#3260088 - 01/25/14 09:18 PM Re: Different size filters?? [Re: 65f100]
tojo1968 Offline
Loc: orlando fl
Are the can diameters the same?
#3260093 - 01/25/14 09:36 PM Re: Different size filters?? [Re: tojo1968]
65f100 Offline
Loc: Oklahoma
Yes, the diameters are the same.
#3260110 - 01/25/14 10:02 PM Re: Different size filters?? [Re: tojo1968]
KCJeep Offline
Loc: Mahzurrah!
If the Microgard is one of the ecore versions the ecores are always a little shorter.
No idea's on the Baldwin though they use coil springs like Wix does so it wouldn't be coil spring vs leaf spring.
2004 Jeep Grand 4.0 @ 133k Pennzoil HM 10w30 w/ 1 qt 10w40
Fram PH8A
KIA Sedona 63k, Ford Focus 116k, Chrysler Sebring 186k, Chrysler Concorde 120k
#3260137 - 01/25/14 10:24 PM Re: Different size filters?? [Re: 65f100]
tojo1968 Offline
Loc: orlando fl
See, that's what's throwing me off. With mine, not only is the length smaller, so is the diameter.
#3260165 - 01/25/14 11:05 PM Re: Different size filters?? [Re: tojo1968]
ZeeOSix Offline
Loc: PNW
LOL ... so if a filter was 100% efficient it would be the size of a thimble? grin
Filters are getting smaller because the filter designers/manufacturers have realized that engines are cleaner today and larger filters are "overkill" for the OCI when a smaller sized filter can still do the job just fine.
So they slowly cut the size back ("boil the frog slowly") to save costs and make more profit to boot. Plus, if they media is efficient and can still flow well without much more delta-p across the element then the smaller size is not hindering flow performance to any notable degree.
#3260382 - 01/26/14 09:22 AM Re: Different size filters?? [Re: tojo1968]
Sayjac Offline
Loc: The Old North State
Using the Fram look up as cross reference, while the M1-108 will likely work if the gasket sizes are the same, the longer/larger M1-104 is the spec, and the equivalent of the larger/longer 9688. In this case,the downsize is two sizes, using Purolator as the example, it went from the 14459 spec size, to the shorty 14612 size, even skipping the the 14610 size. Thus there is a difference not only in length, but in diameter too. I would be less than pleased, especially for using a premium filter and the two size downsize differential. If one specifically enters the M1-104 in the O'R lookup and then clicks the compatibility tab, 08 Sportage is listed. Other than trying to downsize customers, ie., save money, no idea why the M1 look up lists the thimble size M1-108.
As the MGL has had so many makers can't speak to the difference in length. But as typical for Wix, it's external to centertube/media element thread end bypass takes up a significant amount of space in the can. So, the Baldwin and the Wix may have similar media area, or the Baldwin 'could' even have more media. Especially in the smaller filter applications, the Wix thread end bypass displaces a significant amount space that is used for media in dome end bypass filters or mostly internal centertube thread end bypass filters like Motorcraft and M1.
... The guy behind the counter said they are smaller because they are more efficient??
As ZO alluded to, pearls from the counter jocks.
#3260409 - 01/26/14 09:59 AM Re: Different size filters?? [Re: Sayjac]
tojo1968 Offline
Loc: orlando fl
Thanks! I'm going by the store to exchange them today.
I have done enough OC's in the last 25 yrs to know this guy was not a fountain of knowledge! Hopefully his advice wont damage someone's engine.
#3260650 - 01/26/14 03:09 PM Re: Different size filters?? [Re: tojo1968]
tojo1968 Offline
Loc: orlando fl
*UPDATE*
Exchanged the 108 for the 104. The 104 is the same size as the Fram on the wife's Kia.
Thanks all for your input!!
Different guy at the parts counter today said he has had a few people come in this month to exchange filters because of size difference.
Page 1 of 2 1 2 >
