I work at a boat,rv storage facility with over 370 units obtaining boats, watercraft or rvs of some sort....
Overs the years of working there, I've had many people tell me that after they used tcw3 as a additive during the boating season they've made little discoveries that made them keep using it...simple things like, the boat doesn't stall in the marina anymore, the generator starts up without a choke, the rv got 1 mpg more leaving last year and 2heading back
Little things that they felt adding it to their fuel was benefiting them....
Now (I) get a little more technical...
I started using it after I got my 97f150. She ran wonderful, no reason to add anything to it. Started like a champ, ran wonderful, pulled my 5000lb boat like a champ...
For 6 months, I religiously got 16.5, on my 11 drive to work... and 15.5 on the way home, my cold starts were ALWAYS 1550rpm (obd2 reader to my phone)
The day before I introduced tcw3 into the fuel system... I took a arrowhead bottle and filled it half way up, made 3marks (idle cold, idle hot, idle hot in gear) a I fixed it with Velcro to my dash...
After the first week, my mpg to work went up 1 mpg home, same as before
Second week, 2mpg on the way to work, and 1mpg home.
For a solid month after that (40gallons ish) I got 18.8on the way to work and 15.5on the way home.
At the end of the 3rd month, I topped out at 19.5-20.5 to work and 18 home...
My cold starts have become 1470ish and on mornings where I have the whole road to myself, I have reached 22mpg heading to work...
I know there are people who refuse to acknowledge (adding oil to gas increases mpg and cleans the motor) but I've been thrilled with my increase after getting the exact same mpg for 6months...
I'm even more thrilled with the Briggs motor that my buddys generator showed me with the cleaning properties of tcw3, his generator had 750hrs on it and I told him to add an Oz to his tank (5 gallon overhead tank) I pulled the head off of it when he serviced it and took a picture, he ran 15 gallons of gas through it and when I pulled the head off again, there was no carbon/flakes/build up like before and I read the numbers off the piston top! ( spent 2hrs doing both views and $15in head gaskets, so it was well worth the time and cash)
I know there's always gonna be the nay Sayers to adding the oil to your gas. So please don't ever follow my footsteps and do it! Its dangerous!!!
But along with my mpg increase, I run a rich mix to my pressure washer to keep the floats from sticking, it goes in my 85 350day cruiser, my 110inch Harley, and dads evo.
EVERYTHING I OWN THAT RUNS OFF GASOLINE !
Things that keep me using on a regular basis, are the situations I stumble upon at work.
A lady had a clogged injector on her pickup, she said it has been clogged for the last year, I put the mix in her fuel (she said to) and after 2weeks the motor smoothed out and the code went away.
I honestly can't count how many people started using it in desert toys or small engines or those that sit and become amazed how smooth everything becomes...
I've been using tcw3to treat gas for everyday use and storage or just to maintain a certain health to neglected things around the household. I strongly believe in it, I've had probably 80people come tell me how much they liked using it, I've told hundreds of people to use it in my time of working at a boat storage lot.
