09 VW Passat Wagon 2.0TSI 4900mi Castrol 0w40 Euro
by gerkin85
9 minutes 40 seconds ago
Oil/filter recommendation for short trips
by DrRoughneck
12 minutes 5 seconds ago
Auto Zone brand oil on clearance (YMMV)
by blupupher
Today at 11:20 AM
M1 5w30 HM / 5512 Miles / Turbo with Towing
by Astro_Guy
Today at 11:10 AM
My 2003 Dodge Dakota
by HM12460
Today at 08:37 AM
Check out the head off my extreme oil burner Honda
by Gasbuggy
Today at 01:31 AM
Unused Bosch 3313 cartridge
by Run
Yesterday at 11:14 PM
David Fry in his own words
by Merkava_4
Yesterday at 11:02 PM
Schaeffer 711 10w30 Detroit 60 12.7
by TiredTrucker
Yesterday at 09:17 PM
2012 Mazdaspeed3 transaxle 36k OCI 75W80
by MD1032
Yesterday at 09:13 PM
Ford announces new assembly plant in Mexico.
by mrsilv04
Yesterday at 09:10 PM
Guy with a cart full of Euro 5W40
by ledslinger
Yesterday at 08:51 PM
slewman, lithium1189, Monktana, djh3, Compignite
56850 Registered Users
115 registered (aircooled, Al, bbhero, 2015_PSD, 87sammy, AMC, 6 invisible), 1706 Guests and 200 Spiders online.
56850 Members
66 Forums
244405 Topics
Page 2 of 2 < 1 2
#3256020 - 01/22/14 09:03 AM Re: long term use of quaker state oil? [Re: leroyd92]
Ramblejam Offline
Loc: Kentucky
In that case, you're good to go (even back in '85, 15w-40 was approved by GM down to 10F in your 454). Enjoy the Delvac!
#3256475 - 01/22/14 03:55 PM Re: long term use of quaker state oil? [Re: Ramblejam]
leroyd92 Offline
Loc: AZ
So since u seem like a 1540 fan, can you clarify this for me?
Is ALL 1540 oil the same rated oil (diesel grade)? I ask cause I think supertech makes a 5quart jug for like under $13 at my WalMart.
If this is the case, I think I'll start getting oil for the fleet here in a few days... I'll still check the rotella/delvac bottle for the ratings and compare it to the jugs they have but I'm just a tad curious to know NOW! lol
Supertech Junky
#3256614 - 01/22/14 06:45 PM Re: long term use of quaker state oil? [Re: leroyd92]
901Memphis Offline
Loc: Northern Kentucky
All 15w40 is not created equal. Just like passenger Car oil you have different formulations to meet even the same specs. Depending on her long you plan on keeping the oil in service, you would probably be well suited to using the Supertech unless you want to extend your drain interval otherwise you might want to pay extra for something stronger.
Here are some quick searchs I found.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1633073
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1415835
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1166942
Check the dates though some formulas might be different now just showing you examples of additive differences.
2002 Buick Century 118k - Built 4T65e - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317
#3256644 - 01/22/14 07:09 PM Re: long term use of quaker state oil? [Re: leroyd92]
Ramblejam Offline
Loc: Kentucky
I'm a fan of the right oil for the application -- hence why I have 5w-20 in my 225,000 mile farm pickup.
You'll find that most of the mainline ratings (API, ACEA, Caterpillar, Cummins, Volvo, etc) will be identical, with a bit of variance on down the line -- for example, Rotella carries JASO MA, whereas Delvac sports the CF-2 approval.
Super Tech 15w-40 is a fine product, although unknown beyond what you see on the label (Citgo, Warren, or whoever was the cheapest source at that time could end up bottle) -- if I were trying to go with the lowest price possible for whatever reason, then I'd pick up some large jugs.
With that said, for your applications, I'd still select Delvac. It's a solid, well-known product (great base oil/additive package) at a really good price.
#3256850 - 01/22/14 09:24 PM Re: long term use of quaker state oil? [Re: leroyd92]
clinebarger Offline
Loc: Fort Worth, Texas
Mobil Delvac 15w40 is spark ignition rated "SM".
2001 Chevy Camaro 5.3L/4L65E, Former V6 car
2010 Toyota Corolla 2ZR-FE/Auto
#3257135 - 01/23/14 07:47 AM Re: long term use of quaker state oil? [Re: leroyd92]
leroyd92 Offline
Loc: AZ
I've decided between delvac and rotella, now, my only issue, i might go rotellamjust so i can get the bbiigg 5gallon bottle!
But i might just buy delvac and forget about it....
I'm totally for (right oil for right app )to, but i own nothing new enough to be crucial to run the correct viscosity...
I may, say i needs be picky about Mt f150 only wanting 5/30and being a 97... that's my newest motor with under 94xxx on it...
Supertech Junky
#3257140 - 01/23/14 07:56 AM Re: long term use of quaker state oil? [Re: leroyd92]
leroyd92 Offline
Loc: AZ
What temps does a diesel run at? Or the temp the oil is rated at to endure the shear resistance? I'm thinking about switching to 1540 in my 110ci Harley motor that gets oil 270at its peak and regularly sits at 200/250
Supertech Junky
#3257769 - 01/23/14 05:48 PM Re: long term use of quaker state oil? [Re: leroyd92]
clinebarger Offline
Delvac, Rotella, Delo 400, & Valvoline premium blue are ALL good choices for your 454 in hot climate, I've ran several big blocks with HDEO with no problems, Probably OK in your Harley, But maybe someone with more air cooled engine experience will chime in.
I would stick with a 5w30 on the F-150.
#3257775 - 01/23/14 05:56 PM Re: long term use of quaker state oil? [Re: clinebarger]
leroyd92 Offline
Loc: AZ
I'm really thinking it.
15wt is 3times higher then what she calls for, might be too much too soon
Supertech Junky
#3257878 - 01/23/14 07:35 PM Re: long term use of quaker state oil? [Re: leroyd92]
Garak Offline
Loc: Regina, Saskatchewan, Canada
That's available in a 5 gallon pail, too.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3258413 - 01/24/14 09:26 AM Re: long term use of quaker state oil? [Re: Garak]
leroyd92 Offline
Loc: AZ
Picked up 2 gallons of rotella t 1540 and a Purolator oil filter...Poped the lid on the rotella and that stuff smells wicked.... it reminds me of the (Mobil 530 clean )that I bought a long time ago...
Next trip. I'll be buying the 5gallon pale, maybe...
I'll change the Volvo oil today and start it tomorrow morning before work.
Supertech Junky
#3258708 - 01/24/14 02:21 PM Re: long term use of quaker state oil? [Re: leroyd92]
volk06 Offline
Loc: Iowa
15wXX is not 3 times thicker than 5wXX oil.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#3259059 - 01/24/14 08:51 PM Re: long term use of quaker state oil? [Re: volk06]
leroyd92 Offline
Loc: AZ
Isn't the base number for dinosaur oil the actual weight of the oil being used? And the determination of how strong/weak the oil is?
My Harley manual showed something about the larger varying numbers between cold start and temp rating the weaker the oil...
Im still unclear about multi grade and its make up. My first bike was straight weight 60 so I had no worries about thinking about oil lolololol
I just don't know how much my 90k mile f150willmthank me if I jump from 5w30 to 15w40.which feels like 2050 gtx imho
Supertech Junky
#3259101 - 01/24/14 10:08 PM Re: long term use of quaker state oil? [Re: leroyd92]
volk06 Offline
Loc: Iowa
No. The base number or TBN tells you how much life your oil has. It measures an oils ability to neutralize acids over your OCI. The base number does tell how strong an oil is based on that. This is completely different than base oils. Base oils or base stocks are different groups of oil to make motor oil. An oil gets it weight from flow properties and viscosities at 40c and 100c. You should read motor oil 101 on the home page.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#3269785 - 02/04/14 12:59 AM Re: long term use of quaker state oil? [Re: leroyd92]
Triton_330 Offline
Loc: Illinois, USA
3.0 mercrusier, 89 tbi 350, 85carbed 350 volvo engine, possibly my 85 carbed 454
And no, I don't want a best oil thread, I'm looking at long term use with this oil
Sorry if this was answered already, I only quickly skimmed through before posting. What vehicle has the 89 350tbi? And how many miles are on it?
I have an 89 Camaro with a 305tbi... I'd not run diesel oil in that engine. My sig shows that it has PYB in it now, but it has used other brands also, but all were gas oils, not diesel. I'm not saying you shouldn't run diesel oil in yours, but it would probably be better off with 5w-30 API SM or SM oils, rather than a diesel oil.
'01 Ford F-150 XLT 5.4L w/K&N CAI ~125k
-> Castrol Magnatec 5w-20 w/Fram Ulra
'89 Chevy Camaro RS 305 TBI ~47.5k
-> Pennzoil YB 5w-30 w/AC Delco
Page 2 of 2 < 1 2
