Wix coolant filter change and cut open
by A310
05/31/16 03:45 AM
O2 Sensor Voltage
by Falcon_LS
05/31/16 01:36 AM
Electrical shock at the grocery store
by Merkava_4
05/30/16 11:42 PM
Another should I change my oil thread
by dan_erickson
05/30/16 10:53 PM
new HDM part number for lacrosse headlamp recall
by lucerne06
05/30/16 08:48 PM
snapper blade control is stiff
by edwardh1
05/30/16 08:44 PM
is my extension cord bad?
by motor_oil_madman
05/30/16 08:33 PM
Done with Sandisk USB Sticks
by JHZR2
05/30/16 08:20 PM
Pineapple Margaritas
by sleddriver
05/30/16 08:12 PM
Replacing Drywall In The Bathroom (Insulation)
by Warstud
05/30/16 07:56 PM
351W build with a flat tappet
by ssregal39
05/30/16 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
05/30/16 07:12 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
31 registered (bourne, chrisri, ActionJoe, BigD1, czbrian, car51, 6 invisible), 514 Guests and 316 Spiders online.
58031 Members
66 Forums
249618 Topics
Page 1 of 3 1 2 3 >
#3254391 - 01/20/14 07:52 PM best warm up patern in winther.
shDK Offline
Loc: Denmark
Hi all.
I am gonna share a discussion with you all that,s bin up here during the winther. Should you let your engine warm up a bit before driving?perhaps the time it takes to scrape off ice from the Windows. Or remove ice first and then just start and go?
The side on the start and drive made the following points.
1. The catalyst converter don,t work till the engine is warm and therefore will pollute more.
2. The engine doesn't warm up at idle but has to work before getting warm.
3. You will delute your engine oil with petrol due to blowby(or undercompression as it,s called here). And incomplete burning(don,t know how else to translate it)
4. Many modern engines has a pretty low oilpressure at idle, to reduce internal mechanical drag. And therefore. The wear is bigger.
The side that,s for letting the engine idle while scraping of ice.
1 the engine will mostly need between 15-20 sec before being fully lubricated(Probertly mostly with older thicker types of oil and engines.
2. The idle at cold start is often pretty high. An example is my Mazda that idles at 2000 rpm at cold start. Therefore it incomplete burning ain,t that big a problem.
3. In favor of safety it is best if the car is free of any moist of the Windows before ddriving. It is hard when you do the start and go way.
So. What do all the experts here say? This winther has bin really mild. But a normal whinther we will have night temps down to -15--20 celcius..
I apologize if my spelling is bad. I am sitting up at night, becouse I have the pneumonia. On both lungs. So now at is tea and rum time:-)
Have a nice day.
Søren
Edited by shDK (01/20/14 07:54 PM)
#3254399 - 01/20/14 08:02 PM Re: best warm up patern in winther. [Re: shDK]
Donald Offline
Loc: Upstate NY
I do not see a need for a long warm up, but warming up the car while one scrapes ice off the windows seems reasonable. But if its cold and no ice, then as soon as I see oil pressure in my gauge I will drive off.
Now if its below 5F my Jeep makes some odd engine noises, so I wait until the engine sounds normal (which might be a minute or two) then drive off.
And then there are the days I use the remote starter because I do not want to be cold.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3254403 - 01/20/14 08:06 PM Re: best warm up patern in winther. [Re: shDK]
Danno Offline
Loc: Northern Ontario, Canada
Hey shDK - Get better soon. You are warm this winter, we are cold, expecting -30C tonight without wind chill -42C with wind chill. Using 0W-20 M1 in the 3 cars parked outside. 2 cars parked inside get 5W-20/30 (warranty required)
I like your second option the best.
#3254444 - 01/20/14 08:48 PM Re: best warm up patern in winther. [Re: shDK]
eljefino Offline
Loc: ME
This keeps coming up. There are lots of threads from a couple weeks ago during the "Polar Vortex" on this very subject.
I nod to safety, particularly fogging up windows. So I idle, destructive as it may be. My goal is to counteract this with better maintenance, and not eliminate it. I own my car; it doesn't own me.
#3254449 - 01/20/14 08:52 PM Re: best warm up patern in winther. [Re: shDK]
KB2008X Offline
Loc: St. Louis, MO.
My rule is that I'll wait five to 10 seconds in the summer and then drive. That works well until the freezing point and then I'll add another 5 seconds, when it gets near 0 Fahrenheit I'll wait maybe 30 seconds. Waiting longer really serves no purpose. There is nothing wrong with waiting longer for whatever reason, you may not gain much, but there is no harm.
The thing to keep in mind is that it's not only the engine that needs to have oil circulated throughout before driving off, regardless of temperature, but the transmission, power steering, drive axle, etc. The colder it is the longer it takes for fluids to circulate. So, once you're rolling, go easy for a few miles and then let it rip.
As for making allowances for "incomplete burning", or letting the converter warm up or pollution, don't worry about that. If you're really worried about pollution ride a bicycle.
04 Town Car 4.6 5w20 FL820S
92 Ram D150 3.9 10w30 MO-090
03 S-10 4.3 5w30 Puro L10111
above on TropArtic Synthetic Blend
10 Toyota Camry - undecided
#3254459 - 01/20/14 09:00 PM Re: best warm up patern in winther. [Re: shDK]
crazyoildude Offline
Loc: New Jersey
at 20 degrees i let them warm up 5 to 7 minutes in the summer i let them warm up 2 minutes
#3254471 - 01/20/14 09:14 PM Re: best warm up patern in winther. [Re: shDK]
sciphi Offline
Loc: Upstate NY
Start it, put on the seatbelt, tune the radio, and go. That usually takes 10-15 seconds. The manual transmission isn't lubricated unless the car is moving, so I use a quality synthetic lube in there.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
#3254483 - 01/20/14 09:27 PM Re: best warm up patern in winther. [Re: shDK]
gregk24 Offline
Loc: FL, USA
Just because the engine has oil pressure doesnt mean its lubricated. I let it idle until the rpm starts to drop down, then I put it in drive and take it easy until its warmed up.
2012 Honda Accord EX-L
Taffeta White - Ivory
38,xxx miles
PPPP 0w20 / Fram Ultra
#3254521 - 01/20/14 09:48 PM Re: best warm up patern in winther. [Re: shDK]
Doog Offline
Loc: North Coast
below 20F I let it sit for 10 minutes. In Summer...30-45 seconds.
The difference between a beer and your opinion is that I asked for a beer... well except for just now..:-)
#3254529 - 01/20/14 09:55 PM Re: best warm up patern in winther. [Re: shDK]
expat Offline
Loc: Canada
I would say much depends on how hard you will work the engine once you get going.
I have the luxury that I have about 1 minutes driving before I need to even get up to 50kph.
So, (unless I need to scrape) I start and Go.
#3254534 - 01/20/14 09:57 PM Re: best warm up patern in winther. [Re: shDK]
spasm3 Offline
Loc: out there
I agree its better to start up and drive off leisurely. But I have wondered about situations in cold weather where you have to accelerate into traffic right off the bat. Are you better to let it run 5 minutes or just start up and go even if you are hitting say 4k rpm?
Edited by spasm3 (01/20/14 09:59 PM)
13 elantra 46k 5w30 ultra
03 chevy avalanche67k pyb
02 saturnsc1 66k 0w40 castrol
01 saturnsc1 185k being rebuilt
93 ciera 79k 5w30 havo
#3254548 - 01/20/14 10:12 PM Re: best warm up patern in winther. [Re: crazyoildude]
Finz Offline
Loc: Northern NJ
+1... Maybe it's a jersey thing.
God Bless America... We really need it about now
06 Odyssey
06 Civic coupe
05 Accord 2.4 sedan
11 Civic 1.8 sedan
98 Accord 2.3 sedan
#3254583 - 01/20/14 10:56 PM Re: best warm up patern in winther. [Re: gregk24]
gathermewool Offline
Loc: New England
That's pretty much exactly what it means...
I like the thought mentioned above, that my vehicle serves me, not the other way around. When I'm by myself, the temperatures aren't ridiculously low, and/or the humidity doesn't mean instant-visibility-killing fog I clear the windows, if applicable, start, and drive off. Otherwise, I'll warm'er up for a minutes while clearing snow and setting the defroster on high, or remote-start and let'er warm up if that's what I want that time.
14 Forester XT
PUPPP + Subie blue filter
08 Civic LX (Auto)
VWB 5W-20 + Fram Ultra (3rd OFI)
#3254591 - 01/20/14 11:06 PM Re: best warm up patern in winther. [Re: shDK]
bvance554 Offline
Loc: VA
When i was a kid back in the 80's my neighbor would wake me up in the morning 'warming up' his car. His 'warming up' consisted of starting the car and holding his foot on the accelerator revving it to ungodly rpm's for about two minutes, then drop it in drive and go. Even as a kid i didn't think this was the best method. For me, start it up, i can scrape the windows in about a minute, then drive it easy.
#3254598 - 01/20/14 11:17 PM Re: best warm up patern in winther. [Re: shDK]
JHZR2 Offline
Loc: New Jersey
Modern cars with properly working and heated O2 sensors should go closed loop pretty fast. How well/fast they get out of the algorithm holding idle a bit faster may be a different story. However if you can go closed loop, you don't have a ton to worry about.
So IMO the best thing from an engine longevity point of view is to use a block heater if equipped, then to start the car, let it stabilize for a few seconds to perhaps a minute at most, then go. Driving should always be gentle, but especially for the first 20 miles/minutes. However, that's the case in ANY weather. When combustion processes are over 1000 degrees, and cooling systems are designed to disperse all heat in >100 degree conditions, the difference in operation from a cold design day to a hot one is kind of small.
Page 1 of 3 1 2 3 >
