Honda GX35 question
by dirtydannyd
07/25/16 02:08 AM
Need advices for oil filter inspection
by ST2008
07/25/16 01:45 AM
Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
07/25/16 01:06 AM
Clean battery with garden hose?
by SavagePatch
07/24/16 11:55 PM
Toyota 5w20 blend?
by researcher
07/24/16 11:36 PM
Smoked some baby backs today
by BeerCan
07/24/16 10:28 PM
Ford FWD axle replacement
by 2009Edge
07/24/16 10:27 PM
Saturn ac compressor
by spasm3
07/24/16 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
07/24/16 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
07/24/16 10:11 PM
moly + engine coatings
by benjy
07/24/16 09:57 PM
Worth the upgrade?
by daves87rs
07/24/16 09:47 PM
curiousaboutoil, 01CAMRY, corndogzombie, NJ1911, SneakyTacos
58587 Registered Users
58 registered (AlienBug, aquariuscsm, B320i, 2009Edge, Astro14, Al, 5 invisible), 1200 Guests and 11 Spiders online.
58587 Members
66 Forums
252222 Topics
Page 1 of 2 1 2 >
#3247286 - 01/13/14 05:41 PM Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST
Jeffry Offline
Loc: IL
I plan on using M1 5w20 EP in my 2014 Fiesta ST with the 1.6 Ecoboost. My concern is that the engine specs 5w20 semi synthetic at a 10k OCI.
I am concerned about heat and wear with a small displacement, turbo, DI, VVT engine.
My driving is 10 miles each way (magic number) with 50% city/50% highway, and occasional long trips. I plan on a 5k OCI with an L20195 purolator (factory spec is tiny fl910s)
Will running 5w20 M1 EP/L20195 protect my engine/turbo? I cannot seem to find TEOST results for the 5w20.
I know the 0w20 was exempted from the GF5 TEOST test because it couldnt pass.
I was looking at HTO-06 certified oils and they all fall in the 5w30 viscosity.
Thinking about using the 5w30; however, there is no mention in the USA manual regarding this; however, in the EU manual, 5w30 is allowed.
Thoughts?
#3247299 - 01/13/14 05:54 PM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: Jeffry]
tig1 Offline
Loc: Illinois
If your engine calls for 5-20 then M1 5-20EP is fine. Also M1 5-20 or M1 0-20.
2007 Ford Fusion 184,000 miles
M1 0-20 AFE
2007 Ford Focus 156,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#3247306 - 01/13/14 05:59 PM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: tig1]
Jeffry Offline
Loc: IL
I would definitely agree if it were a PI/NA/non VCT engine. After ford's specification debacle on the ecoboost in the F150, I am not sure I can trust the engineers.
After all, 10k OCI on a DI/Turbo/VVT motor with a 4 quart sump on semi syn, is also specified
#3247308 - 01/13/14 06:01 PM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: Jeffry]
tig1 Offline
Loc: Illinois
What debacle?
M1 0-20 AFE
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#3247328 - 01/13/14 06:20 PM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: Jeffry]
dparm Offline
Loc: Chicago, IL
In the Focus ST, Ford actually requires an oil meeting WSS-M2C946-A (certain 5w30s). I would assume the same requirement applies on yours, but check the owner's manual.
2011 BMW M3 sedan ZCP
#3247366 - 01/13/14 06:49 PM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: Jeffry]
toneydoc Offline
Loc: War Eagle
That Mobil 1 EP will definitely work in that application. Decent price at Wal mart. Use without hesitation.
1994 Jeep 146k Castrol 0w40
2014 Camry 15k TGMO 0w20
2010 Sebring 40k Valvoline 5w30
2014 HD Ultra 18k Valv20w50
2012 Toyota Rav4 22k Mobil 1 0w30AFE
#3247373 - 01/13/14 07:00 PM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: Jeffry]
DuckRyder Offline
Loc: Atlanta
According to the Fiesta ST supplement:
http://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/14fstst1e.pdf
It takes:
Motorcraft SAE 5W-20 Premium
Synthetic Blend Motor Oil or equivalent
Or
Motorcraft SAE 5W- 20 Full Synthetic Motor Oil
WSS-M2C945-A
Mobil says 5w-20EP meets WSS-M2C945-A
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
  • 2012 Volkswagen Jetta TDi
#3247379 - 01/13/14 07:04 PM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: Jeffry]
volk06 Offline
Loc: Iowa
These small 4 cylinder ecoboosts have not shown to have major fuel dilution problems and are easier on the oil than earlier ecoboosts. The Turbos are water cooled so that greatly reduces the stress on the oil. The turbos and DI aren't much of an issue on these engines. Those ecoboost can do a 10K OCI without a problem. Now the 3.5L ecoboost, it also specs a 10K but with 5w30, it destroys the oil but that has not show any negative effect, yet.
Your choice of 5w20 M1 EP will provide you with excellent protection for that 10K OCI if you choose to go that long.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#3247788 - 01/14/14 06:53 AM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: Jeffry]
rossn2 Offline
Loc: Ft Hood Texas area
What Ecoboost debacle? Please clarify.
I have owned two of the ecoboost engines and have had no issues with either of them.
Edited by rossn2 (01/14/14 06:55 AM)
2015 Ram 1500 Crewcab Laramie, 4x4, 3.21 rear and Hemi
2016 Hyundai Tuscon ECO 4cyl (33mpg)
2015 FLHTK (Stage IV kit, 106 HP) 2013 CVO Ultra,
#3247871 - 01/14/14 08:46 AM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: Jeffry]
Mach1Owner Offline
Loc: PA
Why not just run Motorcraft semi or full synthetic?
Its good oil and its what Ford produces.
Also Ford has had VCT engines running 5w-30 since 1997. I would recommends 0w just for less stress on the system during cold start up. I know that on past systems it was oil driven, I'm not sure if it still is or not.
I ran two VCT I4 motors for over 7 years and neither had an issue with 5w-30 or 5w-20.
Edited by Mach1Owner (01/14/14 08:54 AM)
'14 Altima 2.5 S: K&N Intake, M1 0w-20 w/ Nissan filter
Past: '91 Taurus, '01 ZX2, '00 ZX2 S/R, '03 Mach1
Ask me about Zetecs!
#3247872 - 01/14/14 08:50 AM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: Jeffry]
Zaedock Offline
Loc: Massachusetts
5K OCI with Mobil 1 EP is an absolute waste.
Follow your manual. 7.5K - 10K changes are the norm.
2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2004 Malibu Maxx LT
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#3252767 - 01/19/14 08:36 AM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: Jeffry]
BTCCA4 Offline
Loc: Orange County, NY
Got mine in November.. Did 2 "flush out" O/C's at 1k & 2k miles respectively with Motorcraft 5W20. Although I'm a big Mobil1 fan, I think I am going to stick with Motorcraft oil & filter on the ST @ 5k intervals. You can pick up oil & filter for 20 bucks at WalMart. Cheap DIY.
My suggestions for your first o/c..
1. Use the OEM 910S. The filter is tucked up around a few hoses & a longer filter makes it that much harder. There is a spring clamp on one of heat exchanger hoses that must be spun around. Do it & you will gain about 50% more filter access clearance. The factory filter is on wicked tight! Plan on a fight! The filter is mounted dead horizontal. I hate dry filter installs on turbos. Add about 3oz of oil to the filter & let the paper absorb the oil while you are draining. Spin the filter on & the oil light will go out instantly.
2.The dipstick is near impossible to read. The bullet shape has no indentations to fill with oil to get a visual reading. Use an automatic punch or a small drill bit to create some oil voids on the dipstick.
When I figure out how to add an image, I'll post it.
Hope this helps!
#3255366 - 01/21/14 05:32 PM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: BTCCA4]
Jeffry Offline
Loc: IL
Hope this helps!
Already did the first OC at ~1500 miles prior to posting this thread. I used OE Motorcraft semi syn which will be run to 5000 miles and a purolator L20195. The OE filter was torqued to yield :P.
Reading fresh 5w20 off the stick is a pain in the butt. I used the dry crank (Flood clear) method to get oil pressure into the filter.
1. Hold clutch and gas to the floor
2. press start button and behold dry cranking
3. after 5 seconds release foot off gas
4. car will start
The car holds exactly 5 quarts with the L20195 smile
I am going synthetic simply for the peace of mind and the fact that the NOACK/SAPS levels are lower than the semi-syn.
It is also wicked cheap at advance auto right now (buy 5 qts and pick out most expensive filter that M1 makes, return to pep boys for store credit to use when they run M1 on special) comes out to ~4 dollars a qt.
Thanks!
#3255379 - 01/21/14 05:44 PM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: Jeffry]
SatinSilver Offline
Loc: Ohio
Not many posts since joining up in 2008. smile
2012 Toyota Camry 62k miles- PP 0w20, oem filter (TGMO all prior)
2005 Toyota Matrix 103k miles- MC 0w20 syn-blend, MC 822 filter
#3255381 - 01/21/14 05:46 PM Re: Mobil 1 Extended Perf 5w20 in 2014 Fiesta ST [Re: Jeffry]
Danh Offline
Loc: Illinois
I agree it makes sense to be cautious with a turbocharged DI engine, especially one that doesn't have a ton of real-world exposure.
The oils you mentioned will be fine, but you may also want to consider Pennzoil Ultra. The benefit of this oil in your application is its very low Noack value, made possible by Gas-to-Liquid base stocks.
There's considerable discussion that Ultra and Pennzoil Platinum may be combined into a single oil, but it would still have the GTL base stock and low Noack.
Page 1 of 2 1 2 >
