Your FINAL though on Quaker State oil line
by MetalSlug
07/27/16 07:45 AM
Amsoil SS 5w30, 10K, 04 Chevy Tahoe, 206K
by dhellman12
07/27/16 07:30 AM
2004 Chevy 2500HD, 60k Amsoil ATF, 194K
by dhellman12
07/27/16 07:17 AM
The History of Snake Oil
by Char Baby
07/27/16 07:16 AM
Industrial hand cleaners?
by KenO
07/26/16 11:58 PM
Shell Rotella T6 in a Altima 2.5
by Grambo
07/26/16 11:24 PM
"Creaking" Conti DWS's?
by Lolvoguy
07/26/16 10:52 PM
Check your car after it's been worked on
by Nick1994
07/26/16 10:15 PM
How are lg android devices now days?
by ram_man
07/26/16 09:42 PM
Dexos 5w30 with highest 100c Viscosity
by CapitalTruck
07/26/16 09:32 PM
How do you avoid being perceived as a rookie when
by motor_oil_madman
07/26/16 09:27 PM
Oil opinions after dumping FF
by JoelB
07/26/16 09:27 PM
snydercn, surfbum, Tmemz4, woollum86, Phil108
58612 Registered Users
63 registered (Bamaro, Bandito440, Anduril, badtlc, bbhero, Andrei, 4 invisible), 1554 Guests and 13 Spiders online.
58612 Members
66 Forums
252300 Topics
Page 1 of 2 1 2 >
#3246745 - 01/13/14 09:56 AM Honda spark plugs
Schmoe Offline
Loc: Oklahoma
Was at the Honda dealership on saturday getting some parts for my CRV, 100000 mile tune up. Some things are Honda only so I had no choice but to go there. Thought since I was there, might as well get the spark plugs. I know they'd be a little more....but the plugs were 28 bucks apiece...YEE-OUCH. But, getting 100K miles of trouble free maintenance is pretty good insurance as well. However, got to looking around the internet today and saw that these plugs go anywhere from 17 to 25 dollars apiece. Now my question, is there something special about these plugs that come from the dealership? I mean, you match up part numbers and you get this wide swing of prices. I don't get it. Would the plugs that were way cheaper somehow different? Honda uses NGK laser iridium plugs on that specific model. Why the spread? Debating on taking them back and saving some coin, but the one place I found these plugs on line said they were Honda OE and those were 25 apiece. The other sites had the correct part number and all, but no mention of them being Honda OE. I know Honda engines are VERY SPECIFIC when it comes to plugs. Should I just take the bullet and shut up or can I get the exact same thing for like 50 bucks cheaper??
01 Supercrew Lariat 4X4
06 Accord EX V6
10 CRV EX-L
(traded 02 Accord EX V6 @ 208K miles for)
14 CRV EX-L
(traded 10 CRV for)
#3246756 - 01/13/14 10:02 AM Re: Honda spark plugs [Re: Schmoe]
Miller88 Online   content
Loc: Onondaga County
Iridium plugs aren't cheap, but $28 a piece is a bit high. You can probably get the same plug elsewhere for quite a bit less. Maybe in the $15 range.
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3246765 - 01/13/14 10:14 AM Re: Honda spark plugs [Re: Schmoe]
hattaresguy Offline
Loc: CT
Buy aftermarket, Honda doesn't make their own plugs they are probably NGK.
Mercedes does this, they put their fancy box on Bosch plugs and triple the price!
#3246772 - 01/13/14 10:18 AM Re: Honda spark plugs [Re: Schmoe]
SatinSilver Offline
Loc: Ohio
Take them back! Absolute rip off. You can get the same Iridium NGK's(or Denso) at Advance for around $10 each.
2012 Toyota Camry 62k miles- PP 0w20, oem filter (TGMO all prior)
2005 Toyota Matrix 103k miles- MC 0w20 syn-blend, MC 822 filter
#3246774 - 01/13/14 10:19 AM Re: Honda spark plugs [Re: Schmoe]
Kool1 Offline
Loc: California
Honda uses Denso coils and they aren't the same as the Denso coils in the aftermarket. I replaced the coils at 150,000 miles in my CRV with Denso "first time fit" aftermarket coils. They produce less spark. The corona around the plugs is less; also after five thousand miles I pulled the plugs and can see that they aren't as white as the old plugs.
Honda on some apps uses Gates hoses from the factory. The aftermarket Gates replacement hoses are slightly thinner and weigh less than the factory Honda Gates hoses. At least that's what I remember from a few years back.
Spark plugs may be a whole different matter. I can't remember if my factory Denso spark plugs looked exactly like the aftermarket Denso spark plugs I replaced them with. I do remember that the vehicle ran the same with the old as with the new plugs.
#3246777 - 01/13/14 10:21 AM Re: Honda spark plugs [Re: Schmoe]
InvalidUserID Offline
Loc: Bay Area, CA
A little poking around and I bet you'll find the exact NGK PN#. Def wouldn't get it from the dealership.
My Cars aka old reliables:
- '96 Camaro 3800 II
- '97 4.0 Grand Cherokee
- '99 Civic EX
#3246792 - 01/13/14 10:36 AM Re: Honda spark plugs [Re: Schmoe]
david_ES2 Offline
Loc: Fresno, CA
You will find the direct replacement NGK LASER IRIDIUM under your application at oreillys, much better price
Honda specs a denso or ngk 100,000 mile iridium or double platinum plug
2004 Honda Civic EX K20Z1 5w30 PP WIX XP
#3246800 - 01/13/14 10:42 AM Re: Honda spark plugs [Re: Schmoe]
Tegger Offline
Loc: Canada
You can get the exact same thing anywhere. You just need the plug number.
Raise the hood and find the emissions sticker. The specified plug maker and number will be on that sticker.
You may find both Denso and NGK numbers listed. NGK may be easier to find.
Now call a couple of jobbers in your area and get prices on that make and number.
2013 Toyota RAV4 - 55,000 miles - Toyota 0W-20, Toyota filter
#3246815 - 01/13/14 10:59 AM Re: Honda spark plugs [Re: Schmoe]
Eddie Offline
Loc: Florida, Cape Coral
$28 Should be the cost of the plug, including the cost to install them. :-)
CX5 Touring 2.5L :-)
#3246830 - 01/13/14 11:16 AM Re: Honda spark plugs [Re: Schmoe]
Schmoe Offline
Loc: Oklahoma
Thanks.....popping the hood is a good idea and double checking. What is irking me is akin to what kool1 is saying....even though it's the same part number, some times they are still "different." I just know when it comes to plugs, Honda's are really finicky. I looked at some OEM honda sites, and they got plugs, but for some reason, the ones they have aren't for 2010 CRV.....I'm guess emission related.
06 Accord EX V6
10 CRV EX-L
14 CRV EX-L
(traded 10 CRV for)
#3246832 - 01/13/14 11:20 AM Re: Honda spark plugs [Re: Schmoe]
SatinSilver Offline
Loc: Ohio
www.collegehillshondaparts.com is well regarded and lists plugs for a 2010 CRV.
#3246835 - 01/13/14 11:24 AM Re: Honda spark plugs [Re: Schmoe]
redhat Offline
Loc: Western New York
09 Accord Sedan 5MT - T6 5W-40, WIX 53756, 104k
14 Civic EX Coupe - Castrol Edge 0W-20, WIX 57356, 26k
#3246836 - 01/13/14 11:26 AM Re: Honda spark plugs [Re: Schmoe]
Tegger Offline
Loc: Canada
The emissions sticker IS the final word on the correct plugs for your car. The sticker is on the underside of the hood. The sticker even takes precedence over the Owner's Manual, since it's illegal for an automaker to put incorrect information on the emissions sticker.
Occasionally the sticker's listed plug will be superseded by a later model, but the jobber will have that information on file and will be able to get you the correct plugs.
Very unlikely. If the number is correct, the plug is correct.
#3246870 - 01/13/14 12:00 PM Re: Honda spark plugs [Re: Schmoe]
racin4ds Offline
Loc: Winchester, VA
Hondas aren't that picky with plugs at all, not sure where you got that from. Just use an NGK or Denso and it'll be just fine. smile
kool1- how in the heck did you verify and compare the "corona" and arc of the given coils accurately???? not buying it...
Just say NO to thin oils!
#3246914 - 01/13/14 12:30 PM Re: Honda spark plugs [Re: racin4ds]
There are people that say you can only use Brand X plugs in a Ford, but avoid Brand X and use brand Y in a Chrysler. Of course, you can't put brand Z plugs in a GM product ... even though the coils are made by brand Z!!!!
A copper plug is a copper plug is a copper plug. A platinum plug is a platinum plug is a platinum plug. An iridium plug is an iridium plug is an iridium plug.
I put NGK Platinum plugs in my Cherokee (specified for copper) and Autolite platinum in my Focus (specified for iridium). Sometimes cost / availability play roles in which plugs we buy.
Both vehicles run excellent.
Page 1 of 2 1 2 >
