Accord door lock issue....
by gregk24
07/31/16 12:26 AM
2000 Corolla vvt-i rattle on startup?
by 55Test
07/30/16 11:24 PM
Brought home a beater today
by exranger06
07/30/16 11:03 PM
Can someone explain to me the nomenclature of ammo
by Vern_in_IL
07/30/16 10:52 PM
Common for bad shift solenoids to shift good warm?
by DemoFly
07/30/16 09:50 PM
Riding mower with non bearing front wheels
by JHZR2
07/30/16 09:17 PM
Mail popup
by Eddie
07/30/16 09:05 PM
Tundra headlight restoration..
by kenwin30
07/30/16 09:00 PM
High mileage and severe service...
by OneEyeJack
07/30/16 08:44 PM
Who uses Quicksilver Multi-purpose oil
by BrocLuno
07/30/16 08:07 PM
Gumout Q&A with Ryan Tuerck - Answers
by wwillson
07/30/16 07:37 PM
Friend Picked Up New 2017 Hyundai Santa Fe Today
by crazyoildude
07/30/16 07:07 PM
danthemann, rodder98, kenb777, Indyfan3, RM53119
58651 Registered Users
22 registered (alcyon, DevilsRule, Chris B., bdcardinal, bamorris2, Blkstanger, 1 invisible), 720 Guests and 5 Spiders online.
58651 Members
66 Forums
252471 Topics
#3195286 - 11/22/13 10:09 PM RB211 side smoke?
crinkles Offline
Loc: Australia
We took a flight from Johannesburg to Sydney recently on Qantas Flight 64. It is operated by a 747-400 with Rolls-Royce RB211-524G-T engines.
We were sitting on the right outside window, and could see engine #4 (and none other). On taxi we noticed smoke coming from a port on the side of the engine. Swirling, not jetting. This continued during takeoff, and climbout, but obviously became a smoother stream on climbout.
It is disconcerting to see this at the start of a 12 hour flight across the Southern Ocean (Went down to 51 degree south). I assumed they knew what they were doing though...
The smoke was white, probably oil related? As the sun set pretty quick after climbout, didn't pay it a second thought. Taxiing on the ground in Sydney, the swirling smoke was still billowing out.
Was this engine burning oil? does it need a seal replacement?
Here is a good photo, on a different airline though, but same port - just under the Rolls Royce decal.
http://www.airliners.net/photo/Cathay-Pa...732b0b51c77ef00
http://www.gcmap.com/mapui?P=jnb-syd
Edited by crinkles (11/22/13 10:16 PM)
2002 Toyota Camry 2.4L
2005 Toyota Camry 2.4L
#3195307 - 11/22/13 10:54 PM Re: RB211 side smoke? [Re: crinkles]
expat Offline
Loc: Canada
"It is disconcerting to see this at the start of a 12 hour flight across the Southern Ocean (Went down to 51 degree south). I assumed they knew what they were doing though...
The smoke was white, probably oil related?"
It's British, it's supposed to do that.
#3195324 - 11/22/13 11:20 PM Re: RB211 side smoke? [Re: crinkles]
MolaKule Offline
Loc: Iowegia - USA
The Rolls-Royce RB211-524G-T is the more fuel efficient version of
the RB211 with a Trent Hot core section and an extra bleed valve.
I suspect the bleed was actually steam.
Or else it needs a serious head gasket replacement. grin2 oilburner
I don't care what religion you are as long as you use your turn signal. smile
#3195398 - 11/23/13 07:08 AM Re: RB211 side smoke? [Re: MolaKule]
JetStar Offline
Loc: Flatlands of Indiana
My first thought was a bearing sump vent, but I don't know RR engines very well.
My weakness is I love all motorcycles regardless of brand
2016 Suzuki DR650
2015 Road Glide
2007 Yamaha FZ1
1978 Suzuki GS1000 (now 1085)
#3195474 - 11/23/13 08:33 AM Re: RB211 side smoke? [Re: crinkles]
Astro14 Offline
Loc: Virginia Beach
Oil vent most likely.
But jet engines hold quite a bit of oil and the pilots have oil pressure, oil temperature and oil quantity gauges. The aircraft monitors those parameters as well...to provide warning if a parameter reaches an alert or critical level. The airline monitors consumption and does analysis on the oil.
So, nothing to worry about, frankly.
32 Packard 15W40
90 4Runner 10W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W40 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
16 Tundra 1794 TGMO
#3196435 - 11/24/13 09:01 AM Re: RB211 side smoke? [Re: crinkles]
Cujet Offline
Loc: Jupiter, Florida
Absolutely normal for rolls engines. They use pressurized labyrinth seals, with no mechanical seal at all. The outboard vent you see is much the same as a crankcase vent going overboard on a car, instead of a PCV system. It will show oil vapor. In cruise flight, it seals very well and little oil is lost.
Other manufacturers do it differently and you don't see the oil mist.
On our company jet, a G550, both Br710 engines have oil vapor swirling about at idle. I think it looks cheap. But, oil consumption is nil, so it must be as effective as any other system.
Edited by Cujet (11/24/13 09:04 AM)
Turbo's rule.
#3197213 - 11/25/13 12:53 AM Re: RB211 side smoke? [Re: crinkles]
crinkles Offline
Loc: Australia
Thanks guys. Great Info. Would the amount of venting be different from engine to engine? This is the first time I've seen it. Perhaps that engine was a bit more worn?
#3197714 - 11/25/13 01:25 PM Re: RB211 side smoke? [Re: crinkles]
Astro14 Offline
Loc: Virginia Beach
Yes, the venting will vary from engine to engine...these things all have large sumps, scavenge pumps, air/oil coolers, fuel/oil coolers, etc...pretty robust oil systems to feed the bearings oil at a nice, stable temperature and pressure....
32 Packard 15W40
05 MB S600 0W40 M1
16 Tundra 1794 TGMO
#3210283 - 12/08/13 10:57 AM Re: RB211 side smoke? [Re: JetStar]
Propflux01 Offline
Loc: Arkansastan
My thinking as well (labyrinth seal). I've seen that a lot on T-56, but out the combined bottom drain.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
#3218072 - 12/16/13 04:59 AM Re: RB211 side smoke? [Re: crinkles]
john_pifer Offline
Loc: Nashville, TN via Memphis
The RB-211 bankrupted RR. They'd be outta business today had the Brit govt not bailed them out.
16 WRX - PPPP 10W-30
07 Tacoma V6 - M1 EP 5W-30, 182K, 10K OCIs
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
