UOA, Pennzoil Platinum 5W30, 15K KM, 10 months
by ST2008
08/26/16 06:19 PM
Cruise control going downhill
by Donald
08/26/16 05:58 PM
O'REILLY SYNTHETIC OIL
by dooscoop32
08/26/16 05:10 PM
Anyone here a ice road truckee?
by car51
08/26/16 04:42 PM
What is business model of UBER ride-hailing co. ?
by HTSS_TR
08/26/16 04:12 PM
Old wall furnace
by Jarlaxle
08/26/16 02:55 PM
automatic side folding mirror squeak
by Grambo
08/26/16 02:11 PM
Anybody own a new Mazda 6?
by AirgunSavant
08/26/16 01:58 PM
Do Employees Of Car Companies Get New Cars Cheap ?
by crazyoildude
08/26/16 01:54 PM
Amsoil SVG 75W90, 50K, 04 Duramax 196K
by dhellman12
08/26/16 01:53 PM
When an orifice is needed & when it is not (long)
by ryaneirich
08/26/16 01:38 PM
UT-Austin Response to CC
by sleddriver
08/26/16 01:36 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
92 registered (andrewp1998, 123Saab, 1JZ_E46, Al, AirgunSavant, albertdi, 7 invisible), 1554 Guests and 40 Spiders online.
58935 Members
66 Forums
253592 Topics
#3195955 - 11/23/13 06:54 PM Oil recommendations for daily + track car?
Mobs Offline
Loc: Australia
Hi all, hoping you can help with some advice about what is important in an oil for my two cars. I'd like to share the same oil if it isn't a compromise.
My daily-driver is a 2003 Volvo S60 with a non-turbo engine. The car is at ~140,000kms and seems to run well except for some moderate noise which is probably old age. The car is manual and revs quite a bit more than most, I am somewhat hard on it. Manual suggests 5w-30 or 10w-40 for my temperature range.
My other car is a custom built car with an SR20DET (S14) turbo engine, well worn w/ stock internals. It gets about 80% of its use on the track (very hot), with the rest gentle road driving for maintenance or to/from track. It has an air/oil cooler and if anything takes a bit too long to warm up - I am yet to measure oil temps however.
Temperatures here in Aus are never below 0, and most of the year is 25-35C.
Currently I am using Penrite HPR5 which is 5w-40 in both and claims 'full zinc'. http://www.penriteoil.com.au/pis_pdfs/7HPR%205%20June%202013.pdf
I feel that I might need something a little better for the track use, perhaps a 10w-40 with the highest hths possible?
How does Delvac 1 ESP 5w-40 perform in this kind of environment? Is it really better with carbon than other oils? The SR20 turns oil black very quickly and will be retuned shortly - hopefully this will improve.
Mobil1 5w-50 was another thought but it might be too heavy for the daily duties?
Edited by Mobs (11/23/13 06:56 PM)
#3195959 - 11/23/13 06:56 PM Re: Oil recommendations for daily + track car? [Re: Mobs]
gregk24 Offline
Loc: FL, USA
What about Mobil 1 0w40...or Rotella T6?
2012 Honda Accord EX-L
Taffeta White - Ivory
40,xxx miles
PPPP 0w20 / Fram Ultra
#3195961 - 11/23/13 06:58 PM Re: Oil recommendations for daily + track car? [Re: Mobs]
Mobs Offline
Loc: Australia
Why would you choose them? I'm not sure what I need other than a high hths and some reasonable zinc or similar for the SR20?
#3195965 - 11/23/13 07:04 PM Re: Oil recommendations for daily + track car? [Re: Mobs]
dparm Offline
Loc: Chicago, IL
M1 0w40 is a streetable race oil. Tons of guys here use it on their DDs that go to the track; there are a lot of M3 owners who use it year-round as well.
2011 BMW M3 sedan ZCP
#3196012 - 11/23/13 08:00 PM Re: Oil recommendations for daily + track car? [Re: dparm]
binkis Offline
Loc: Maryland U.S.A
Got castrol?
#3196128 - 11/23/13 10:07 PM Re: Oil recommendations for daily + track car? [Re: Mobs]
Raybo Offline
Loc: Clearwater ,Florida
SR20DET is a monster little motor. Talking about that for years when I owned a 240SX and lived over at Fresh Alloy.com
Want to blow your mind? Try Redline 10-40 motor oil.Best motor oil you'll ever use.It will feel like a different motor.
Please try it.
#3196518 - 11/24/13 10:11 AM Re: Oil recommendations for daily + track car? [Re: dparm]
SteveSRT8 Offline
Loc: Sunny Florida
Hope it is as available there as it is one of the best.
OP, without knowing the real temp and psi values when at the track there is no way you can pick a viscosity.
Thicker oil simply means hotter temps in most tracked cars.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3196825 - 11/24/13 05:00 PM Re: Oil recommendations for daily + track car? [Re: Raybo]
sammy Offline
Loc: California
Please try it.
What this guy said. I haven't tried every motor oil but I've ran a lot of them. This one makes a difference. I'm glad I found Bobistheoilguy because if nothing else it led me to try Redline in the performance engine. I have specific issues that redline literally fixed, but even if I didn't have those issues my study of oil says this is the best stuff. I think Motul is basically the same, just French made not USA, but either would be great for your application.
#3196858 - 11/24/13 05:36 PM Re: Oil recommendations for daily + track car? [Re: Mobs]
gpshumway Offline
Loc: Minneapolis, MN
Got an oil temp gauge in your SR20? If not, I'd suggest you get one, it will help you know what grade is most appropriate. If your oil temps at the track are over 120*C an oil cooler is probably a better modification than different oil.
Do you have some reason to believe the Penrite is not doing well? Have you done oil analysis? I don't know that much about Penrite, but the PDS you linked seems to indicate it's pretty good stuff. It's pretty similar to Rotella T6 and Mobil 1 Turbo Diesel Truck, a Full-SAPS 5w40 mixed fleet (petrol/diesel) oil not suitable for engines with diesel particulate filters. Delvac 1 ESP is a "low-saps" oil for engines with DPF, it may result in fewer deposits in the intake tract, but in a track car all it really means is you won't have to clean the intake as often. I would bet Delvac 1 ESP and Penrite HPR5 perform very similarly, they're very similar from a viscosity perspective.
Highest HTHS is not necessarily better, as long as your oil has "enough" there's no benefit to having more. If you're not seeing substantial amounts of lead or copper from engine or turbo bearings in the UOA, and your oil temperatures are under control, I don't think more HTHS is necessary. With HTHS of 3.9 the Penrite is already quite high, as I said before, the better solution is cooler oil. I don't know if the SR20 (or your particular SR20) has piston cooling jets, but if it does, cooler oil equates directly to a cooler combustion chamber and more margin against detonation.
If you must switch oils, commonly cited street/track oils are Motul 300V and Redline. They've been joined recently by Joe Gibbs Driven, but I have no idea if that's available in OZ. Depending on your oil temps, I would actually suggest Redline 5w30 (HTHS 3.7) instead of the 10w40 mentioned above. Joe Gibbs driven LS30 would be a good choice if your oil temps are under good control(<120*C), or DT40 if it runs a bit hotter.
I use Redline 5w30 in my WRX and have been very happy.
Good luck!
2007 Subaru WRX
2011 Honda Civic EX
#3197165 - 11/24/13 10:35 PM Re: Oil recommendations for daily + track car? [Re: Mobs]
AdamC Offline
Loc: NSW, AU
I use mobil 0w-40 in my 300kw rb26dett. I have an oil cooler and keep the temp under 120 degC at the track. If you're in Sydney you can get the Mobil via an ebay seller who imports quarts from the US, to avoid the Australia tax. eg around $70 for 6 quarts vs $95 for 5 liters. Dont know if he delivers.
R32 GTR - Mobil 0w-40
M35 Stagea - Mobil 0w-40
#3197218 - 11/25/13 01:39 AM Re: Oil recommendations for daily + track car? [Re: Mobs]
supercity Offline
Loc: Australia
HPR 5 should do as good a job as any other full saps Euro 5w40. It even has official LL-01 and 229.5 approvals where most others don't. M1 0w40 is the most respected in this class and would do the job well but it's just so expensive here.
I have a similar application and ended up choosing D1 ESP 5w40 also. Other options I concidered were Penrite Racing 10w40 or M1 5w50.
#3197953 - 11/25/13 05:18 PM Re: Oil recommendations for daily + track car? [Re: supercity]
Mobs Offline
Loc: Australia
Thanks all, I really appreciate the insight. The next step is to measure oil temps and pressures on the track and get back to you. Car is currently being rewired and will be up and running soon.
Should I have any concern running the M1 0W-40 when I would normally run a 5W-40 or similar? Is it just a matter of checking for sufficient oil pressure at lower operating temps?
Edited by Mobs (11/25/13 05:18 PM)
#3197993 - 11/25/13 06:04 PM Re: Oil recommendations for daily + track car? [Re: Mobs]
gpshumway Offline
Shouldn't be any concerns with M1 0w40. 5w40s are usually slightly more shear stable and maybe a bit more resistant to fuel dilution, but M1 0w40 is good stuff. Your engine would have to be right on the edge of having problems for the difference to matter.
2007 Subaru WRX
2011 Honda Civic EX
