Originally Posted By: fins
I have a 2010 Toyota Camry 2.4 Hybrid
I like to use an oversize filter if possible because I like the extra filtering capacity (not here to debate oil filter sizes).
Can anyone give me a part number for an oversize filter to fit my engine?
What is your OCI duration, and do you intend to alter it significantly?
Adding capacity, over the OEM choice that probably already can go 2x the OCI, is moot.
Do it because you "want" to, not because you'll ever see any tangible benefit.
Donaldson has a nice attribute search feature; you can look up your filter, then search others based upon the physical criteria (threads, gasket size, etc).
Beforewarned about the warranty risks of venturing off the reservation ...
