Hey all, I posted a while back about looking for a "new to me" truck here:
http://www.bobistheoilguy.com/forums/ubb...095#Post3118095
Well, after looking at countless Silverados and F-150s, I'm the proud new owner of an extended cab 2001 Silverado 1500 Z71 with the 5.3, 4L60-E trans and 3.73 gears. No rust, minimal dings and no apparent problems. It currently has 167k miles but it literally drives like new. After talking with the PO I knew the truck had a fresh fill of 10w-30 Valvoline conventional, Microguard oil filter and Lucas oil stabilizer added a week ago. I asked him why he added the Lucas and he told me he did it because he read it was good stuff on a GM truck forum. Naturally, as a BITOGer, I got it home and replaced the oil in favor of 5w-30 Maxlife and a P1 filter. I'm sure I'll be good on my oil and filter choice but I know NOTHING about the rest of the truck.
There is no history of maintenance and the PO (owner for the last 40k miles) stated he had no idea if the trans or motor had ever been rebuilt (this was factored into the price, and there is no evidence suggesting either). Obviously I want to swap the trans, xfer case, brake and diff fluid in order to get a starting point for maintenance.
I have a few questions:
1. The 4L60-E, assuming it has never been rebuilt, shifts fine. I'll use Dexron-VI, do a drain and fill, drive for a week, do a pan drop/filter change then do another drain and fill a week later. Thoughts?
2. Engine looks fine through the fill hole, no crud in the pan when the oil was changed, purrs like a kitten at idle and pulls nicely at higher RPM. No miss, no pinging, seems perfect. 5w-30 Maxlife a good choice?
3. Front and rear diff - Has the G80 Eaton locker in the rear, no clue about the front. I'm getting conflicting info and am completely lost here.
4. Transfer case - Autotrac. Do I really need the GM juice? Completely lost here, too.
5. Coolant - Dexcool or what?
