I decided to cut open a new Bosch Premium #3500 designed for a Ford V8.I'm using this filter in my 4.0L Jeep because it is the oversize filter for my application.I looked inside the thing when I purchased it and couldn't see any type of by-pass valve.Figurede there has to be one and will find it next oil change when I cut it open.Couldn't wait and cut open a new one.Luckily I did...there is NO by-pass valve AT ALL.Nothing on the base plate,just the DBV and on top the spring that holds the filter can in place to the baseplate has one big hole in..and the top of the endplate has smalller holes that butt against the spring.. it but there is NO WAY it can by-pass...I tried believe me...***...so I had an old Mobil oil filter out back draining.It is the #301 for the same application...cut it open and it HAS a baseplate by-pass valve that worked great when I shoved a small screwdriver into it.OK...it must be hidden in the centre column of the media tube...ripped off the media...NOTHING!OFF that POS comes!I realize that G.M has a block by-pass system and a filter system would be moot for a by-pass...but does the 302 or the 351 have an engine block by-pass as well?
